Question about Microsoft Xbox 360 Console
Error 0102 on xbox
Hello again thanks for replying, i tried your method but no luck. i wait like 10 secs n then the rrod comes on after turning the xbox on.nothing shows on the tv aswell. Is it my dodgy eraser pads or coz ive used a 6 cm screw in the heat sink which has meant it as gone right thru the top of the heat sink and hanging out the top. but it is still keeping the heat sink reasonable tight. Would it be becoz i havnt done the xclamp on the cpu? n e ideas?, and wen i overheat it do i do it with fan off or on but oni cooling the cpu?,
Cheers brendan
    Problem Solver:
  • 11 Answers
Is it the heatsink is tight enough and the position of the heatsink are balance or not because if the heatsink not balance gpu or cpu will not properly transfer the heat and make sure to there is no component touching the heatsink suchas condensator on the left of the main memory ic's with brown color 2 thiny things, and that my your console still 3rrod. if you have done check it up repeat the instuction from the fist and the fan is on and the shroud was in original place and heat up the console with towel for fasting the heat.
note. the 3rrod came because the component soldering not properly soldered or that had sort contact with the other component.
Posted on Jul 29, 2008
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Sep 06, 2010 | Microsoft Xbox 360 Pro System Console
I took my 360 apart because my brother got it from an the expo center (it had no warrenty) and i got the E73 so i overheated it by unpluging the fan on the inside. i waited and then turned it on it was...
The Sticks Method:
Jun 27, 2010 | Microsoft Xbox 360 Console
What do i have to do to fix error code E73
The Sticks Method:
Apr 24, 2010 | Microsoft Xbox Console
My xbox keeps saying e73 can you help
The Sticks Method:
Apr 02, 2010 | Microsoft Xbox Console
E73 xbox
The Sticks Method:
Apr 02, 2010 | Microsoft Xbox 360 Console
How do i fix my xbox 360 e73??
The Sticks Method:
Feb 05, 2010 | Microsoft Xbox 360 Controller
Xbox 360 2 red lights
Its possible you could of overheated the solder under the GPU chip and you may need to have the chip replaced and reflowed. We have had success in reflowing the chip. We are listed on this site for repairs. If interested email us for free estimate.
xbox360fixer@verizon.net
Thanks
Jan 15, 2009 | Microsoft Xbox 360 Console
2 red lights
I suggest you to try DIY Guidethat wil explain solving the 2 red lights along with someother common problems of Xbox like Disc Read Error, No Video Problemand most famous RROD. Even a novice can solve the problem with the helpof step by step process given at the guide. I think it's worth trying.If you try this method, you won't have to wait for 3-4 weeks and youcan enjoy your gaming experience within 2 hours, once you try thisguide.
Jun 23, 2008 | Microsoft Xbox 360 Console
Error code 0102
If you're comfortable enough opening your 360, you can try this tutorial, which has worked for many people.
Jan 07, 2008 | Microsoft Xbox 360 Console
Xbox 360 error 0102
do the erasor trick. its like magic
Nov 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
