Question about Jet Tech Systems 24 in. 737 Free-standing Dishwasher
Water to dishwasher not hot enough
We''ve had 3 dishwashers in our new house, none cleaning dishes. I can tell you that 18" from the dishwasher at the hot water 'T', the water is 135 degrees. A couple of minutes after it enters the dishwasher it is cooled to 107 degrees. It needs to be at least 120 right? Any ideas of how to keep it hot enough. We have a recirculator, but I think it's not on at the moment while we've been trouble shooting. Is it possible that in the 18" of line, that with all dishwashers using so very little water, that the existing water is virtually cold and the little bit that is added only brings it to 107? Help!
    Problem Solver:
  • 25 Answers
The 737 model could run on even lower temperature (80F). Given time, the unit will heat up the water. the trick is to give it time.
That model is made for commercial use, not really for residential. It will not fully drain every cycles. The important thing to keep in mind is to empty the dishwasher (turn it off, pull the stand-pipe out, and drain) every night and left empty. When you want to use the unit, put the plug back in and turn it on, wait 20 to 30 minutes and it should be ready.
Robert Marsolais
Posted on Aug 01, 2008
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
When wash dishes, there is gritty like food on all the dishes and we use liquid for cleaning dishes. I rinse all dishes before I place in unit.....what is the problem?
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.The water temperature should be minimum of 140 degree Fahrenheit.
Also check the filter in your dishwasher for any debris accumulation.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 09, 2010 | Maytag Dishwashers
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
I have a problem with my Sears 18" dishwasher. It doesn't get enough water pressure to properly clean the dishes. Should I call an appliance repair person or a plumber?
You need to cal an appliance repair professional...the dishwasher fills from the house plumbing, but if it is not washing right that is an internal problen with the dishwasher....probably there is stuff in the pump or the pump is going bad...
heatman101
Apr 20, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
GE Quiet Wash 3, top arm does not spin
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
  1. Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
  2. When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Dec 29, 2009 | General Electric Adora GHDA670N Built-in...
My dish washer is not cleaning the dishes properly.it almost seems as if the top rack is no being clean.
try using dishwasher majic or a cleaner / ck the holes in wash arms as the must be clear . clean srreen in bottom and make sure the water tempt is hot enough .min 130 to 140 deg . low water tempt cause=s most dw washability problems . + a fresh dergt. podwer is best as liq freeze in winter and are no good. //**** .hope this helped .
Dec 23, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dish washer runs but doesn't clean? Help
This issue can be caused by:
* Water is not hot enough.
* Be sure you are using dishwasher soap recommended by the manufacturer. Also, if the dishwasher soap is old, it will not clean the dishes properly. Try with a new one.
* The pump (no the drain pump) of the dishwasher is broken, so there is not enough water pressure from the nozzles.
After checking all above the dishwasher doesn't clean properly, it may have a part broken and you may need to request repairs for the dishwasher.
Aug 30, 2009 | Kenmore Dishwashers
Dishwasher leaves film on the dishes
If your dishwasher is a few years old and just started leaving a film on your dishes there is a filter under the bottom adjitator that you have to replace it can't be cleaned jf
Jun 13, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Silverware and dishes not getting clean, leaving grit on dishes
It cleans poorly If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Mar 03, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Jet Tech Systems 24 in. 737 Free-standing Dishwasher Logo
495 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
