Question about Braun Syncro 7526 Electric Shaver
New cleaning solution cartridge leaked
Before I replaced the cleaning solution cartridge with a new one I noticed that at the bottom of the inside of the base was full of trimmed hair. I used Q-tips and a toothpick with hot water to clean and rinse the inside of the base. After replacing the cleaning cartridge and going through one cleaning cycle, the next day my counter was wet with solution and the cartridge light was blinking again. I checked the new cartridge and it almost completely empty.
Any idea's on what happened and how to correct it?
  • erik9999 Jul 30, 2008
    Same problem here, the base leaks immediately after putting in a new cartridge until empty. (1 cycle) This sucks. I am going to take mine apart and see what the problem may be. Something may be clogged or not connecting securely.
    Problem Solver:
  • 37 Answers
If you both have the same problem from the same merchandise, than maybe you should just switch razors and Rely on a different company.
Posted on Aug 19, 2008
How do i put the o rings and springs in my old leaking 2 handle faucet
Make sure the water to the tap set is turned off. Remove the hot plug button, use a small knife to pry it out of the top of handle. Remove the screw inside the handle that holds the handle to the cartridge. Use an adjustable wrench to unscrew the tap handle from the base. Once removed, separate the cartridge from the shell (the unscrew from each other). Use the appropriate size and type of screw driver to remove the screw holding in the flat washer. Using a small dull needle or flat screwdriver remove the "O" ring from the valve stem Replace the o ring by just slipping it on. Make sure you clean all areas of the stem and the stem cartridge of old grease and dirt etc. Use new clean valve stem grease on the O ring before re installing into the cartridge. Insert the new washer onto bottom of valve stem, Screw on. While you have it apart look down inside the tap to inspect the valve seat. If its chipped, broken, rusted etc you MUST replace it, if you do not any new parts will sot stop the leak. Valve seat MUST be nice and flat and clean. To remove the seats most taps will require a 3/8" Allan wrench. Push the wrench into the slot of the seat, turn C-Cw to remove, CW to replace. These parts are cheap. If you need to replace the seat, take it with you to H Depot so they can give you the correct one. NOTE: Its best to do the cold at the same time, saves you the trouble of doing it again later. Same applies to the cartridges. You can replace the entire cartridge instead of rebuilding them at only a few bucks each, its much faster and easier.
Aug 10, 2014 | American Standard Plumbing
Ink is leaking out of ink tanks and filling up maintenance cartridge. Had a extra print head (used) and it did the same thing
1- Remove ALL the ink cartridges from the printer
2- Check that there is no residual tape on the cartridges.
3- Then clean the contacts on the cartridges as well as inside the printer itself
NOTE: Clean the contacts with a small amount of warm water on a cotton swab until no ink comes off on the swab.
4- If any of the other cartridges are low, empty, leaking or bulging, replace them with genuine and original ones.
5- Then turn off the machine and unplug it for 60 seconds
6- Insert the cartridges and check to see if the issue persists
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Canon imagePROGRAF W8400 InkJet Printer
I replaced a new cartridge to my printer and now is not printing. Before I tried to refill the cartridge and it did not work, it was leaking black ink. Now with the new cartridge it does not work either....
Canon PIXMA MX860. Turn it off. Open it and check if the black ink leaked inside most especially on the cartridge panel. Clean there using surgical spirit or petrol using a cloth.
Fit the cartridges in their actual point (Black and Color). Connect its power and USB cables and then switch on. This should work for you.
Jun 15, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Mar 06, 2009 | HP DeskJet 930c InkJet Printer
Ink cartridge
Using some switch cleaner solvent, gently clean the contacts on the cartridge carriage, and also if you have any, use some inkjet cleaner to clean the nozzle where the cartridge sits, this should clean the mechanism sufficiently to allow the printer to detect the cartridge.
Mar 05, 2009 | Epson RX595 Photo All-In-One Printer
How to remove the top of the 952c to get to the ink reservoir.
HP 952c = Deskjet Printer
Like ALL HP deskjets of this design:
Turn Printer ON (allow for test cycle), then lift top hinged panel.
Print cartridges will be parked in protected area to the right.
When top panel is lifted, they will move out for easy access.
They will NOT move out if printer is OFF.
So Please turn ON as first step.
Best to install new cartridges as opposed to cleaning.
If cleaning, utilize software option for clogged cartridges.
If they are leaking, replace them with new cartridges.
All this is available on HP web site.
Aug 04, 2008 | HP DeskJet 952c InkJet Printer
IP4200 Printing wrong color
Try
www.fixyourownprinter.com
In the field type your printer and model
Take no notice of adverts.
Also try Canon support
Jun 08, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer seems to be leaking ink?
take those out are uusing off brand ink
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Braun Syncro 7526 Electric Shaver Logo
174 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
