Question about Baumatic Kitchen Ranges
Oven light comes on oven not getting hot - Baumatic Kitchen Ranges
    Novelist:
  • 116 Answers
There may be a problem with the oven element causing it to need replacement. I will need more information if this is not the case.
Posted on Jul 28, 2008
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
Hot Surface light will not go off, and heat coming from oven.
HOT SURFACE LIGHT STAYS ON WHEN ONE OF THE LIMINTERS ON ONE OF THE BURNERS GOES BAD THE HEAT IN THE OVEN IS TOTALLY DIFFERENT PROBLEM NEED TO GET SOMEONE TO CHECK IT
Jul 22, 2011 | Whirlpool RF341BXKW Electric Kitchen Range
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
There is a red light visable thru the glass top on the left rear of the cooktop. cannot find this light anywhere in the book. it is on and has never come on befor
Yeh,
I ve seen this before.
Try turning on one buner at a time. Make the element red hot!. If one does not get red hot. make a note of that switch.
Some stoves create a way for a technician to know which switch is shorted and uaually it is the one that doesn't get red hot.
If all buners are red hot , preheat oven for 350 and wait. it should take 5min to heat up oven. if oven not hot ,one of the elements is blown
Aug 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
My Amanda gas oven Model no. AGS781WW is not heating up in the oven, nor does the broiler come on. The electronic ignition glows, I don't smell any gas in the oven. The cooktop comes on fine.
even if the ignitor glows it may not be getting hot enough to light the gas. if it does not get hot enough the gas valve should not open. try changing the ignitor, usually 30 - 60 dollars.
Jun 21, 2010 | Ovens
Oven will not come on after cleaning program
probably got to hot and burnt up the sensor. I did the same thing. I would say NEVER use the self clean feature. It gets to hot. My sensor is inside the oven towards the back two little screws remove and un-plug sensor plug in new one Sensor was about ten dollars
Jun 10, 2010 | Ovens
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Oven
the igniter is not getting hot enough. It can get hot enough to allow gas to flow but not quite enough to ignite the gas. It is an easy fix. The igniter is usually under the floor of the oven.
Aug 27, 2008 | DCS RGS-305 Professional Gas Kitchen Range
My oven will not preheat at all.Or basically get hot.
You most likely have a defective oven ignitor. Even if it IS glowing, (orange) it may not be creating the proper resistance to open the gas valve to the oven burner. Once the ignitor is replaced, your oven should come on within 30-45 seconds after you set temperature.
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Kitchen Ranges Logo
113 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Vitaliy Gins
Vitaliy Gins
Treefrog15
Treefrog15
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
