Question about D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server
Adding a second printer to a d-link priter server
A have one printer connected to a print server how do i connect the second printer
  • 35 Answers
You need to connect the second printer to your print server then install the printer driver to your computers. If your print server has a printserver driver, run that so it will automatically find the new printer for you.
Posted on Aug 03, 2008
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
IOGear GPSU21 doesn't work wirelessly with ip4500. Laptop running vista home 64
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
http://www.iogear.com/support/dm/driver/GPSU21#display
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
Thank you and good luck!
May 24, 2010 | IOGear GPSU21 Print Server
I wanted to set up the printserver wirelessly but everytime my computer searches for the printer server, it only registers in the wizard if i connect the WPS54G to the router. If i do this, i am able to...
The printer and print server has to be connected to the wireless router by a network cable for you to print wirelessly from the laptop.
If possible connect a long network cable between the print server and the wireless router or move the router next to the print server and printer.
You maybe able to use a wireless repeater/extender but is it worth the added costs and complication. The extended range would invite hackers unless you secure your system.
Aug 01, 2009 | Linksys Wireless-G WPS54G Print Server
Hi, I connected the printer server GPSU01U to a dlink 524
When you connect the print server to the router, does the lights lit? have you tried to reset the print server (reset button is on the side of the print server). press the reset button for 10 seconds, after 10seconds, while still holding the reset button power cycle the print server (unplug then replug the power cable) then release the reset button. Try to find the print server using the PS admin.
May 17, 2009 | IOGear (GPSR01U) Print Server
Can't print from my mac to my canon mp980 wireless printer
Sounds like when you added xp you inadvertently installed new print driver on server.
Try rolling back driver. But may drop xp from printing.
Best solution network printer to router bypass server. Will require hard wire from printer to router. disconnect from server may need network card for printer.
Mar 08, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Adding another computer to my print server
I need more details on Brand Model and make of your print server please.
Oct 09, 2017 | D-Link DPR1260 Rangebooster G...
Lexmark 4300 series
Open control panel to activate your printer in default /check also device manager if your priter are connected w/ device.
Dec 30, 2007 | Lexmark P4350 All-In-One InkJet Printer
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printer offline
1) Ensure you've run the D-Link supplied automatic configuration wizard. 2) Also ensure you have "Netbios over TCP/IP" enabled in your network settings. 3)Ensure you turn off "Bidirectional Printing" in the Ports tab and "Enabled Advanced printing features" in the advanced tab, for testing purposes. I know the printer connectivity is officially supported by D-Link (thru an independent 3rd party test facility) but it seems they may have had NetBeui installed, which is an outdated networking protocol. Try the first 3 options I gave, if they don't work, then let me know. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server Logo
339 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
