Question about Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-HC32NTSC Play Back
My Handycam records but the touch Icons on the screen do not work when I activate the Play/Edit mode. Any Ideas?
Alan
    Genius:
  • 1,011 Answers
  • 99 Answers
In play/edit mode, most of the menu buttons are "greyed" out, thus unavailable. You cannot all of the camera set menu, but you can use the memory set menu.  In play edit mode you can the following:
  • Various speed playback (VAR.SP PB)
  • Movie Recording Control (REC CTRL)
  • Audio Dubbing (AUD DUB CTRL)
  • Recording Control (REC MOVIE)
  • Burn DVD
  • Burn VCD
  • End Search
As far as I know, these are the only menu items you can access. It's on page 38 and 52 of the user manual You can access that here: http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/warranty/4aee41352763a80604443d48cea4d0848cd567a0.pdf
Posted on Jul 28, 2008
  • Madhav Suresh Jul 28, 2008
    *EDIT
    You cannot access all of the camera set menu
    Guru:
  • 1,894 Answers
This looks like a software problem.
since the touch screen works in other modes the screen fault can be excluded i think.
try updating your firmware sir.
  • Sony Master
  • 19,396 Answers
Normally the touch screen should be activated, try removing battery to reset settings, if touch screen still does not work, then it is faulty.
How do you delete videos from your sony handycam DCR-DVD405
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
Mar 22, 2011 | Sony Handycam DCR-DVD405 Camcorder
On a Sony Handycam DCR-HC28 there are grey lines running horizotally during play back mode. Both on the camera touch screen and on our TV when we play it back.
Cleaned my heads and internals with alcohol and q-tip and blew it out with compressed air( LIGHT PRESSURE) approx 30 lbs press. works great.
Jan 15, 2011 | Sony Handycam DCR-HC28 Mini DV Digital...
My Sony DCR-HC40E has a fault with the touch screen. The touch screen is not displayed so I am unable to play/edit or even record/view anything. The screen is usable if you know where the controls are...
Hi!
The flat LCD cable which goes through the hinges has broken - a common problem with many Sony camcorders. You will have to give it to Sony for repair.
I work for Sony.
Tom
Oct 09, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony Handycam issue - repair/replace?
Your camera has bad CCD Imager and needs to be replaced this part. Good news is Sony will repair your DCR-TRV19E free of cost. Please check Sony Website for details.
Regards,
Aug 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Sony Handycam CCD-TRV37 Camcorder Logo
406 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
