Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Fitting a new electricity cord
The cord has been damaged, how do I replace a new one, what parts have to be dismantled to get to the inside of the cleaner
Posted on Oct 24, 2008
  • 25 Answers
Remove the wheels then you can see the screws not easy to remove the wheels they just pull of
Posted on Sep 05, 2008
How to repair
A wire might have come loose inside the Vacuum head.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
Remove/Dismantle the Vacuum head and locate the wires.
Check the wires at the terminals and at pinch points
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 08, 2014 | Hoover S3670 WindTunnel Bagged Canister...
U5445-900
This is a good start, try this link...
Product Manual Search
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
My hoover vacuum does not power up
Here s a link to the manual
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 15, 2014 | Hoover S3330 / S3332 Straight Suction...
How to replace power cable on hoover jc3157t
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 04, 2014 | Hoover Vacuums
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
The mechanism that rolls back in the power cord seems to be working slower and sometimes not at all. Was wondering if the mechanism in question has an adjustment to increase the tension on it so the power...
it easy to adjust the roll back of vacuums the problem is hard to dismantle the unit to remove all the things to see the adjustment roll,all vacuums is need to remove all screw to open the unit even to replace the small parts like switch,and sometimes we cannot adjust the roll back if the spring is worn out we need to replace the new one,for me much better call and service technician for your comfortable and practically to not damage the other plastic part of the unit.and you get a warranty service for that one.
Jan 01, 2011 | Kenmore Vacuums
How to replace electrical cord on Dyson ball vacuum cleaner. Our puppy chewed it.
Depending on where it has been chewed, you may not need to replace the whole of your cord. Ask your local electrical supplier, or possibly somewhere like B & Q, if they have an 'inline' plug and socket to repair your existing cord.this would resemble the type of plug and socket used to connectd the power chord to a lawnmower, except you would not be buying the sealed type.Then you could simply cut out the chewed part of your ccord, and fit the two new ends, one the plug and the other the socket.It is no more difficlt than fitting a new domestic 13 amp plug on a cable.It is also a safe but much cheaper solution, so you should save money too.
Jul 10, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
The lead on our machine is becoming frayed - is it possible to replace the lead and if so, how is it achieved? John Tuffley
If you are refering to the Electrical Power Cord? Yes, this can be easily replaced or repaired.
Depending upon where the cord is damaged, you can either cut it a little shorter and install a replacement electrical plug end (available at any electrical parts store (Lowes, Home Depot, Radio Shack, etc) for about $2.50.
Or if the cord is damaged near the vacuum, you can purchase another cord or even make up one yourself how ever long you want it within reason.
Jun 15, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Broken electrical cord
The belt can e replaced but I recommend you should take it to your local vacuum cleaner service center. They may even be able to fit a new plug on the end for you if the damage is at the plug end.
Mar 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a d4c rainbow vacuum, need help replacing the electrical cord
There is no reset button, but some of those old switches are very touchy . . . if there was some  corrosion, you may not have a good contact (was enough of the new wire insulation stripped away, before putting it into the switch) . . .
I prefer splicing, rather than going all the way to the switch  . . its just a matter of cutting out the old cord and splicing in the new cord in a convenient spot up in the motor compartment. . . a Rainbow purist would run the new cord all the way up into the power on/off rocker switch that's built into the top of the handle and then wire the new cord in there, directly at the switch . . . that way means no splicing . . . I've done it both ways, but I prefer to splice and use wire connectors inside the motor compartment . . . because going further, all the way up directly into the on/off switch just to avoid splicing the new cord in requires taking more things apart . . . and risks screwing up the power switch . . . that's not worth the extra time and trouble, IMHO.  (This from someone who has dismantled and refurbished over 200 D4C and SE models)
Jul 26, 2007 | Rainbow 75th Anniversary Canister Vacuum
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
135 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
