Question about Nintendo Wii Console
NOT PICKING UP SENSOR
Hi
My friends handset wasn't picking up the sensor, or so they thought, so I took my hand set round and still didn't work - no response, no vibration.
Took the sensor to my house and use my handset and it worked. so the sensor works.
As my handset didn't work on their wii I presume there is nothing wrong with their handsets either.
so is the problem with the console. Is there anything else we can check.
Tks
  • sasbolton Jul 28, 2008
    Tried that, but thanks anyway
    Problem Solver:
  • 13 Answers
Okay i'm not an expert with the sensors so this isn't the best advice. IOf you are no where near the sensor it can't detect the wiimote also too close to the tv is not good. Sorry if this advice is suckish but i'm trying...
Posted on Jul 28, 2008
  • Chanler
    Chanler Jul 28, 2008
    hope
  • Chanler
    this makes you feel better!
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
My linksys router doesnt have a default gateway and the reset buttton on the router doesnt work either
When you look between the Ethernet port and Power button, there should be a reset button there you should hold for 5 seconds. Of course if you do that, If you changed Network name and key that will be reset to the default settings, Also is wireless network showing when you pull up the Networks? You can leave user name blank, but default password is admin. Also email me with more info I will be glad to help
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml
Dec 26, 2011 | Linksys WRT54G3G Wireless Router...
I bought a 97 gp 1200 waverunner and the first few times i took it out it ran great, i changed the spark plugs because it wasn't opening completly up at wide open throttle. I put it the water and it...
THE BEST WAY TO CLEAN OUT YOUR INGINE AND HOSES IS TO HOOK UP THE FLUSH HOSE TO THE SIDE OF THE WATERCRAFT ,,,,IF YOU DONT HAVE THE ADAPTER CONECTION HOSE YOU WILL NEED TO GET ONE ITS A VERRY IMPORTENT PART OF MANTENACE ,,,,YOU NEED TO FLUSH IT OUT EVERY TIME YOU TAKE IT OUT OF THE WATER TO KEEP ALL THE SAND FROM BUILDING UP IN YOUR COOLING SYSTEM,, AND TO GET ALL SALTWATER OUT THE SALTWATER WILL EAT AWAY THE HEAD LITTLE BY LITTLE,,PLEASE NOTE SOME MODELS HAVE A HOOKUP IN THE VERRY BACK WHERE YOU CAN HOOK A REGALAR WATER HOSE TO,,,HOPE THIS HELPS.
Jul 19, 2011 | Yamaha Alp 40 Motorcycles
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
GE 25931 Trio Cordless Phone Answering Problem
Try charging the phone on the main handset - Good luck!
May 21, 2008 | GE 25931 Trio Cordless Phone
Error coes 7
That loose cable sounds like it would be the humidity sensor. They're usually a shielded cable with three pins.
It will usually plug in close to a large resistor, like on the Sharp shown below.
Probably on the upper (display / control) board but I won't wears to that.
If you don't find it, please post a few photos of your board.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 07, 2008 | Whirlpool GH9177XLB Microwave Oven
Phones Not working
I have the same problem, I have the same model and sometimes I have to put the 2nd Handset on the main base and let the main base "rocognize it" before I can use it. That usually fixes the problem for me.
Apr 02, 2007 | GE 25861GE3 Phone
Handsets bypassed; need to restore
I found some old notes of mine you could try, but they're involved: 1. [Spkr],#,603,500,[Speed Dial],[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,656,9,phone extension,[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,657,#,phone extension,[Redial],[Spkr],pick up hand set, hang up. Were you able to find a free manual online? Pat
Feb 20, 2007 | Toshiba DKT-2010 Corded Phone
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
