Question about Emerson EWL3706 37 in. LCD Television
There is a line going across my emerson LCD
Its like my TV screen is divided into two parts. The bottom is abount 5 inches and is darker than the top of the screen. I've only had this tv for 5 months. Is there anything I can do, the warrenty still covers parts but the service store is an hour and a half away
  • kayscleaning Dec 03, 2008
    I have the same problem and I dont know where to take the tv. I brought it from walmart and misplaced the receipt
  • 16 Answers
This is a chip on film problem and cannot be fixed take it back and have it replaced , they may want to send it to a repair site but they will scrap it and you get a new set.
Posted on Oct 09, 2008
Samsung 41" tv has band across top 2/3 of screen . Doesn't go right across to hrs, but is approx 5" wide. Can see picture thru it, but it is much darker in this area. Help!
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 14, 2017 | Samsung Televison & Video
Emerson 32 inch lcd tv there is a pure white line 3 inches high on the bottom of the picture.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 28, 2016 | Emerson Televison & Video
Black line through middle of emerson led tv screen
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Apr 23, 2014 | Emerson Televison & Video
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
At the bottom of the Emerson 32" started to be darker
It's possible that the Power Inverter Board is starting to go out. It has 6 small inverter transformers to power the LCD screen. Each transformer powers one section from top to bottom. If you are a do it yourself-er, shopjimmy.com might have one in stock. Those boards are hard to come by right now. But, if you have warranty it might be cheaper that way.
Feb 02, 2009 | Emerson EWL3706 37 in. LCD Television
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
I have a 37in LCD Emerson tv and there is a division line in the tv. Top is normal bottom is dark. How do i fix it
sounds like a failed backlight or inverter.
larger LCD sets use multiple lamps horizontally across the screen.
Dec 03, 2008 | Emerson EWL3706 37 in. LCD Television
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Emerson EWL3706 37 in. LCD Television Logo
434 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
