Laptop problem I've had my laptop for many monthss now (4months roughly) but it has over the last month slowed right down and the voloume keys on my user name do not work and the volume symble has a ! on it and says there is a problem but this isnt a problem on the other user name. Also it is runing very slowly.
    Champion:
  • 258 Answers
Your registry is full of garbage need cleaning. get registry booster softwaRE. YOU WILL FIND IT
Posted on Jul 29, 2008
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
Compaq presario a902tu
restart the computer HOLD the keys CTRL+F12 OR F11 depend of your model, mark, and go to restore factory default and fix it.
God bless you
Jul 10, 2013 | Computers & Internet
Can't logon to my acer laptop it says the following, the user profile service failed the logon user profile cannot be loaded
Shut down your computer. To do a hard shutdown hold the power button down until it turns off. You probably need it to go to last known good configuration. To to this 1. find the F8 key (keep finger on it(not pushed yet). 2. Turn Power button on and immediately start tapping F8 key. This will take you to a screen with many options; Last Known Good Configuration is one of them. It should start up. Hope this helps.
Apr 27, 2013 | Acer Computers & Internet
Compaq makes short, loud buzz/click sound regularly?
The Laptop is New? One month old? Return it, it may be a bad HDD.
Mar 12, 2013 | Compaq Computers & Internet
2003 Pontiac Vibe - 4 Cyl. 150k miles. Ignition coils keep going bad - every 4-6k miles. Coil 1 has been replaced 4 times, Coil 3 once. Coil 4 twice in the past year (20k miles). All spark plugs
Install new spark plugs, 4 new coils & replace the oxygen sensors
O2 Sensors are only good for 100,000 miles, then slow
down or quite
No idea why the coils do not last 5 or 6 years
Cylinder #1 is always at the front on a 4 cyl
Go to Rock Auto --Buy Wells Coils,NGK Double
Platinum Plugs & NTK O2 Sensor
Those parts are expensive because you have a Totota
Motor I guess
Clean MAF Sensor with CRC MAF Sensor Cleaner
Jan 08, 2013 | 2003 Pontiac Vibe
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
Voloume
Go to the start menu and find the control panel. On it you will find audio, which can be used to control your volume. ou should also be able to place a small icon on your lower toolbar too.
May 24, 2012 | Acer Aspire 5742G
I've been at this all day and still have'nt gotten my laptop to reset to a factory default setting. Can you please guide me through this process, step by step. Thankyou.
You can always restore the computer to a point when it was working fine.
For a laptop when you say factory defaults we've two things
1)Factory defaults on the Bios - as soon as u turn on the laptop we press F8 key or DEL(depends on the brand of the laptop) to get to the BIOS and you've an option to revert to the factory defaults.
It is advisable not touch the BIOS if you are not sure about this firmware
2)The operating system (lik windows xp,vista & 7) there is nothing called factory defaults for this all we've is a installation of the Operating system itself. However we can revert or restore back to last know good configuration mode.
How to start your computer by using the Last Known Good Configuration feature To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER
Aug 18, 2011 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
