Question about Nvidia GeForce 6600 Graphic Card
Agp support in my motherboard a slot of agp 32 bit 4x will it support 256 mb graphiccardor not?????
  • 781 Answers
Only if the card is a 4X one not higher
Posted on Jul 30, 2008
What cheap but good video card should i get to run modern warfare 2 on my dell desktop computer
From what I can determine, for you to have the permornace you need for Modern Warfare 2, the following are the recommended computer requirements:
A CPU: 2.4 GHz dual core or better, RAM: 1 GB on XP / 2 GB on Vista and Windows 7 and a
GeForce 9500 GT 1GB memory Graphics board. (this is a PCI Express slot board).
Make sure your Dell has the slot required for the graphics board, if no slot then there is an AGP board, but with 512MB memory that would work good.
Either graphice baord would cost about them same
Recommend, EVGA @ or Tiger Direct.
Good Luck
Sep 04, 2011 | Nvidia GeForce FX 5500 256 MB, (256 MB)...
I am putting together an ASRock mobo. I am told NOT to use a 3.3v AGP card. as it will damage the board. ASRock K7S41 / K7S41GX. N Videa replys are not specific. I have 3 AGP video cards and have no idea...
Hi, you can download a manual here:
Your mainboard has AGP slot.
  • 1 slot for AGP 8X/4X 1.5V
    The to first one is AGP.
    The last one is PCI-E
    Graphics Processor: NVIDIA GeForce2 MX 200
    NVIDIA Model Number: 8859
    Memory: 64MB
    Outputs: DVI
    Interface / Slot Type: AGP
    • Installed Memory: 32
    • Interface Type: Video - 15 pin High-Density D-shell (VGA)
    • Video Chipset: NVIDIA GeForce2 MX400
    • Slot Type: AGP
    GeForce MX4000 Bus Type PCI Slot Memory on Board 64 MB DDR RAMDAC Support 270 MHz Max. Resolution 2048x1536 8/16/32 bit colors with 60Hz (Analog) Memory Interface 64-bit Display Output Dual VGA
    (1x On-Board VGA,
    1x MD9-pin port supports 1 x VGA) Operating System Support Windows® XP/2K/98//Me/NT 4.0
    Aug 28, 2011 | Asrock K7S41GX Motherboard
    Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
    Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
    Jul 16, 2010 | Microsoft Windows XP Professional SP2
    Is my mobo compatible with a 256 mb 128 bit fx5500 agp video card?
    youre motherboad support intel pentium d 800mhz fsb processor and ddr 400, it has built in graphics, yes it will support a 256 128 bit fx5500 agp card, the agp 8x/agp 3.0 enhance graphics performance it support a high bandwidth speeds up to 2.12gb/s its twice faster than agp 4x,
    Nov 22, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
    What video card is better for my board?
    Hello there Mizrach#03 ...
    The following advice is based on specifications detailed here:
    As I'm sure you already know, you have a relatively limited (older) motherboard (MB) there. But make no mistake, there is absolutely no criticism impiled in the least. After all, if the capabilities of your MB meets your particular needs, then there's nothing "wrong" with it. And let no one tell you otherwise. No one "needs" hardware beyond their "needs".
    That said, THE critical determinant is the "4x AGP" specification. In the simplest terms: Get the best "4x AGP" video card you can get for the money.
    Here's a lineup of solid choices (NOT all are 4x AGP, disregard those that are not):|c:318|&Sort=4
    God-speed, and please post back if you have any further questions, and/or to just let me know how everything worked out.
    "Today's the best day of my life ,,, and NOW you;re part of it!"
    Mar 27, 2009 | EliteGroup P4VMM2 Motherboard
    you have both, 3 pci and one agp 4x.
    Nov 20, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
    Compatible agp card for 8vm533m-rz motherboard
    This board only has a 4X AGP slot so any AGP video card of 4X will do recommend 256MB or more if you can get it
    Sep 25, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
    Suitable Griphics Card
    32 megs of graphix is nothing compared to what they have out nowadays. you need to first find out if you have a pci or an agp port. also, what operating system are you using?
    what you probably need is a 2-4 year old video card which supports agp 4x.
    Jun 28, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
    Agp 8x vs agp 4x
    the 4x card WILL work in an 8x slot but it will only run at 4x speed because of the card limitation. also, the 8x card WILL work in a 4x slot but it will only run at 4x speed because of the slot limitation. i've done it. peace
    Nov 05, 2007 | Palit Microsystems GeForce FX5500, (256...
    Nvidia GeForce 6600 Graphic Card Logo
    47 people viewed this question
    Top Nvidia Computers & Internet Experts
    Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
