Question about Sun MySQL
Insert rows to MySQL
Trying to insert a few hundred rows into MySQL, & every time I get an error message, but if I try to do it 50 in a times, I get an error message only once in a while.
What is the best way to insert rows into MySQL?
  • 71 Answers
Could you give me more info plz
Posted on Jul 30, 2008
Could not connect to MySQL
Hi;
You can start/stop the mysql service on the server by logging into the server as root from the command line interface and run the following command/s.
service mysql stop
service mysql start
service mysql restart
You can also use the following if the above does not work fine.
Fix Toolbox for MySQL
https://www.fixtoolbox.com/repairtoolformysql.html
Jul 07, 2016 | Wolfgang Schmuck MySQL
Mysql> desc contact_info -> ; --------------
Hi David,
It looks like you're missing two more null's in the third record, the column count is only 21 and you have 23 fields in your destination table.
All your data matches up to the columns, but you'll need to insert ", null, null" before the last paren to cover CompanyURL and companyPhone):
('Karson', 'B', 'Campbell', null, 'Dr.', 'Chief Resident', 'Pediatrics', 'kbc232@mvch.org', null, null, '585-544-1212', 'home', '1955-01-05', 'Wife: Molly Kids: Cassidy, Justine, and Cory.', 'Mountain View Hospital', null, null, null, null, null, null, null, null, null, null )
Sep 06, 2013 | Sun MySQL
Mp145 E5 problem
Cannon has made their ink cartridges in a way that you have to buy new ones every couple of refills.This is a way to bypass that..worked on my MP145.
Reset Ink level Canon Printer Cartridges PG-40, CL-41, PG-50, CL-51, CL-52
To reset the ink Level (method 1)
  1. Paste with a thin strip tape the upper horizontal row contacts
  2. Insert the cartridge into the printer and close the lid.
  3. The printer will now on the move, but wait until there on the screen Your computer is the message that there is a wrong way to a Ink cartridge is loaded. Click OK in the message
  4. Open the lid of the printer and remove the cartridge from there.
  5. Download Now the strip of adhesive tape and paste it contact now on the Second row (from top) horizontal contactjes. (Picture 2)
  6. Insert the cartridge into the printer back again and closed the lid. Weather will The printer is on the move again, and again we place an alert on Your monitor. This time, the message that the cartridge can not Be recognized. Click on OK again
  7. Open the printer and remove now for the last time the cartridge from the
  8. Remove the tape and insert the cartridge in the printer and connect it Lid.
  9. The printer is the cartridge back as a new and indicates that the cartridge full again
Resetting the ink Level (method 2)
Works only in some cases
  1. Paste with a thin strip tape the bottom row of horizontal contact The cartridge off
  3. The printer will now on the move, but wait until there on the screen Your computer is reported that on one wrong way Ink cartridge is loaded. Click OK in the message
  5. Download Now the strip of adhesive tape and paste it contactjes now on the Contact uppermost horizontal row.
  7. Open the printer and remove now for the last time the cartridge from the Printer.
if that doesnt help... u will most likely be required to call canon...
thank you for using Fixya....
A very Helpful rating is appreciated...
have a nice day
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp 145 errors E 5
ud semua cara sy coba g mau juga mas, tlng bantuanya mas.
Apr 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Mysql database tables+find new inserted or update row using java
After you add the new record into table A, you can use the LAST_INSERT_ID() function to retrieve the value of the auto_increment PK field. Look here for more information on this function: http://dev.mysql.com/doc/refman/5.0/en/information-functions.html
Mar 02, 2009 | Sun Java Programming Language (cdj-275)
MYSQL Access denied
Hi Buddy,
Try this option....
mysql -u root -p
mysql will then ask you for the password give the proper password.
For changing mysql root password
mysqladmin -u root -p password <<newpwd>>
then mysql ask you to give password this is the old password and now the new password for the root will be newankush.
Sep 10, 2008 | Sun MySQL
MySQL Error
This error means that mysql doesn't have sufficient memory to store the entire query result, so far no rocket science, the first thing you have to do is check your query it might be wrong, is it reasonable that it would return so many rows?
Aug 26, 2008 | Sun MySQL
MySQL Auto Increase
Try this -
CREATE TABLE users (
id MEDIUMINT NOT NULL AUTO_INCREMENT,
login TEXT NOT NULL,
password TEXT NOT NULL,
PRIMARY KEY( id )
INSERT INTO users VALUES ( null, 'bob', 'mypassword' );
INSERT INTO users VALUES ( null, 'bill', 'pass' );
INSERT INTO users VALUES ( null, 'sean', '1234' );
Aug 04, 2008 | Sun MySQL
MySQL can't connect Error
Guess you are referring to this error message -
Check your username & password, and make sure that you are authorized to access the server.
If your password & username are correct, there might be a network problem that prevents you from connecting to the machine where the MySQL server is running. To make sure that they are no network failures, click on the "ping" button.
This will "Ping" the MySQL server host. If the host is available (no network failure), you will
receive a message similar to this -
Reply from 127.0.0.1: Time=0ms TTL=128
Reply from 127.0.0.1: Time=1ms TTL=128
If you don't it means there's a problem with the network.
Jul 27, 2008 | Sun MySQL
MySQL Error Messeage
When you install MySQL for the first time, no password is set for root user.
Move to the installation directory of mysql (cd/usr/local/mysql) Set the password for user, using the following command -
./bin/mysqladmin -u <username> password
Enter your password. Then you can connect to the mysql client as
./bin/mysql -u <username> -p <password>
Sun MySQL Logo
87 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
