Question about Goodman GMS90703BXA Heater
A/C won't turn off regardless of thermostat setting ? GMP075-3 w/ 2 ton A/C
It is now the middle of a hot summer . The system is cooling fine but a problem has developed where the A/C and fan stays on regardless of the thermostat setting . I can only tun it off by placing the switch thermostat in the off position (between heat and cool ) . I suspect that is probably a bad control board or thermostat . How do i diagnosis this further ? - Thanks
  • 1,420 Answers
If you are able to shut the system down by using the thermostat as mentioned, the thermostat is either bad or the programming is messed up. Check the fan switch and turn it to "Auto".
Posted on Aug 07, 2008
Tip
Dear car drivers PA we are in the summer time
i noticed that many over heat problems are showing up lately so dear car drivers please can you save your money/effort and our money/effort in solving problems that you can diagnose or avoid it at all :<br />1 - checking <u><i>water level and oil level<b> </b></i></u><b>make sense</b> in the <b>summer </b>and worth the 10 minutes it takes .<br />(so please check from time to time day by if your <b>car is old</b> original one )<br />2 - some common problem in the summer when car get hot over and over the ignition (<b><u>coil</u></b>) is affected it will make <i><u>your car cold run fine but cuts off when hot </u></i><u>if</u> occurred look for the <u><b>coil </b></u>before ask .<br />3- when car get <u><i>raise in temperature</i></u> only <u>when slow or idle</u> and ac also won`t work in such condition but working fine and <u><i>cools down the engine when running fast </i></u>making the air follow cool the water then it is <b>thermostat </b>replace it
on Jun 07, 2011 | Chevrolet 1500 Cars & Trucks
Ford 302
Make sure the cooling system is not plugged up, poor coolant flow can make your engine run hot, and a plugged heater core will not allow heat in the cabin in the winter.
Aug 10, 2014 | 1990 Ford F150
I have a 1998 Oldsmobile Bravada with automatic climate control that blows cold air in the winter and hot in the summer. The thermostat is working fine and it doesn't need flushed. There are no le
It sounds like the system is fried. Based on the description, it is just pulling in the outside air and not doing anything to heat or cool the flow. Unfortunately, this is a job for your preferred mechanic.
Oct 28, 2012 | 1998 Oldsmobile Bravada
My 2008 ford ranger has a heater that wont get hot.w/temp knob full hot, cold air. Checked fuses. I heard about a "door" inside the heater that can get "stuck", but just rumor. It...
hi Planeman.
Why is the heater in my car not working? Ken Mattson, owner of Len's Automotive in Bellevue, Wash., says a car heater can stop working for a number of reasons, including: A low antifreeze/water level in the radiator due to a leak in the cooling system. A bad thermostat that isn't allowing the engine to properly warm up.11 Dec 2013
Why Isn't My Car Heater Working? ' Angie's List
https://www.angieslist.com/articles/why-isnt-my-car-heater-working.htm Search for: Why is the heater in my car not working?
Why is my car heater not blowing hot air?Hot coolant from the engine passes through a heater core, which looks and functions a lot like a small radiator, and a blower motor forces air through it. ... It's also the reason that a plugged heater core, stuck thermostat, or air in the cooling system can all cause a car's heater to blow cold.9 Jul 2017When Your Car Heater Blows Cold Air - Lifewirehttps://www.lifewire.com/when-your-heater-blows-cold-air-534667
How do you fix the heat in your car?Begin with the vehicle on level ground, engine off (cold) in park with the emergency brake set.Heater Controls. Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. ...Refilling Cooling System. ...Engine Thermostat. ...Blend Door Actuator. ...Broken Vacuum Line. ...Heater Control Valve. ...Vacuum Gauge. ...Heater Core.How to Fix a Car Heater in Under 30 Minutes - 2CarPros
What are the symptoms of a bad thermostat?A motor with a bad thermostat will run fine for the first few minutes, then overheatrapidly. Other symptoms include the engine and radiator making a rumbling, gurgling, boiling sound: like a steam pipe knock, if you've ever heard one of those. A thermostat sticking open can make your heater not work in the winter.Auto, Car, Truck THERMOSTAT Repair bad thermostat symptoms
or go to this link if you need more help.
2008 ford ranger has heater that won get hot Google Search
Nov 19, 2017 | 2008 Ford Ranger
Furnance not heating
Make sure that the thermostat is set for the proper medium that you are using being gas or electric. Inside the cover of the thermostat should be a setting for either eletrical heat or gas heat. Set this switch for what your system is G for gas or E for eletric. This may solve your problem. Good Luck hope this helped you some
Dave
Oct 26, 2009 | Intertherm P3RA-036K Air Conditioner
3 ton condensor and 2.5 air handler
I hate to use rules of thumb but 500sqft per ton depending on your windows and insulation. you are probably ok with a 2.5 ton however it will not work with a 3 ton outdoor unit as you have figured out. depending on how long that ac has been in you may want to replace it with a 2.5 ton due to the damage to the compressor valves because of the mis match. or if the indoor is newer and the original system may have been a 3 ton then i would replace the A/H. and be prepared to replace the outdoor if the valves are to far gone. If the trane is a new high effiency 2 and the goodman is just a 10 SEER you may be able to have a txv installed on the trane unit and a kickstart device outside. but only if its a high effiency but their again if the A/C fails you couldnt have a high effiency 3 ton you would have to drop down to 2.5,
Sep 22, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
136 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
