Question about Maytag Washing Machines
My washing machine is a Maytag Atlantis heavy duty, stainless steel. The machine is around 5 years old. Frequently we have to open the lid and distribute the clothes around, otherwise the drum spins out of control, even with little amount of clothing. Can you advice on what is involved to fix the problem please. Is there a drum kit available? Is it possible to get someone to service on Saturdays? thanks Nick
This is a problem with these machiones. its drum rides on a ball and socket setup. with a plastic ring it rides on to cause the resistance when spinning. also centerd with big springs. its a job to replace . i would get about 200.00 to due.
if you use machine a lot then after another few years same thing again. poor design i think.
good luck.
batpup
Posted on Jul 28, 2008
Maytag Atlantis washing machine SOMETIMES needs a thump to get going after filling up. this question concerns a Maytag Atlantis washing machine, about 10 years old. it has given excellent service so far...
the lid safety switch is not engaged, the hinge clips that go into the body of the washer break up allowing the lid to come out of alignment.thus the switch is not making contact. i had this same problem on my atlantis. it's an easy fix. and the clips are only about 2 bucks at an appliance parts store....
Dec 14, 2010 | Maytag Washing Machines
I have a Speed Queen Heavy Duty Large capacity wash machine model:AWM 351-3062 I need to find out ifit has a steel drum
Yes, all Speed Queens have a stainless steel tub, some are coated, but underneath is stainless steel
Jun 12, 2010 | Washing Machines
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washing machine will not drain
your water pump may be jammed with a sock or something..its in the bottom of the machine
Nov 15, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Older Maytag Washing Machine - Top Loading "Heavy Duty" model
There is a screw near the base of the agitator. If it is missing replace it with a stainless steel screw. If this is a machine that is older than 25 years, you will have to replace the rubber ring on the agitator shaft.
Dec 06, 2007 | Washing Machines
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
