E: drive folder not accessible
I have 80 gb hdd in my home computer, i have create three partition C,E and F and installed two os, one is xp pro. in drive C: and other is win. server 2003 in drive E:, In back both OS were working fine but now i have faceing problem. I am not able to access or copy any E: drive folder it,s giving error E:\ drive not accessible, access denide..
pls give help
thanks
  • 45 Answers
Sorry buddy the win server 2003 locks the content in its installed drive when trying to use it from another OS usually this problem occurs when you try to change some settings in that OS
however you can revert this by editing the gpedit.msc profile in server 2003 run menu
Posted on Jul 28, 2008
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Have 250Gb hard drive. Shows only 127Gb available. Used fdisk to remove and replace partition and reformat drive. No help. Drive is quiet running.
Since you have already posted you are running win xp.
for more info the drive limitations prior to win xp home/pro sp2 is 127 gb.
You can use a seperate partition program for full access to the drive with it being partitioned.
The only way around it is to have win xp home or pro with sp2 already included on the cd.
Mark
Oct 05, 2009 | Computers & Internet
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Full Hard drive
you can merge to partitions on a single disk, although this should be one of your last resorts. when two partitions are created on a single drive the OS recognizes the two partitions as two seperate drives. From win xp pro, you can access all the data on the partition with xp home platform. the second partition will take up close to a gig of space that could be used. the simplest way would be to creat shortcuts to the programs you want in the partition for xp pro. then right click my computer> properties> advanced> start up and recovery settings> select win xp as the default OS and deselect the box marked "time to display operating systems"
this will stop that annoying 30 sec pause that you get when you start your computer asking which OS you want to run.
or if you seriously want to merge the two, here is a link with a download that will help.....download this file and creat an disk to insert into the disk drive and restart to load from the disk
http://download2.lsoft.net/BootDiskDemo-Setup.exe
the only thing is that if you write over or delete files that those programs need to run smoothly, you will have to reinstall them completely. in which case you would be just as well off to back up your info and do a clean install. i trust you will be able to determin which solution is best for you needs.
Personally if i had programs i wanted to save, i would take the first option and just have two partitions
Mar 11, 2009 | Dell Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
Jan 29, 2009 | Computers & Internet
Hdd not showing in my computer
Hi
When ever we connect the new HDD to the system we want to make a Format and partition then only it will work.
Because its new one and then its in raw state, we want to make a Format and partition then only we can use it..
Using the OS u can do the format and partition..
I thing u known how..
All the best..
Thank you
Sep 19, 2008 | Computers & Internet
Hard disk partition table error
Insert windows xp bootable disk and boot your system in CD/DVD and then reformat your HDD and install new windows operating system.
Jan 08, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Computers & Internet Logo
227 people viewed this question
David Payne
David Payne
