Question about Philips DVDR3450H DVD Recorder/HDD Recorder
Fault i have today recieved my philips dvd5500 recorder/freeview . everything checks out fine xcept i can not tune into freeviev chanels useing full or update serch. in digital search mode:no channels found is displayed. in frequency check 150000 to 950000 is ajustable. maybe i need the correct frequency but i thought the full serch would tune in.i live in the jerricho area of oxford my name is kevin saboss
  • 196 Answers
As long as you have a good digital aerial connected to the recorder and you are in a good signal area then the channels should have been found automaticaly and stored on the machine.. a manual search and store would also work ok.. check your aerial connection/aerial type and any info you can find on freeview availabiliy in your area.. do you or anyone in your area have any other freeview device running ok?
Posted on Oct 14, 2008
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
Cant tune in channels on freeveiw (built in to system )
u need to have your aerial cable directled plugged into your freeview box
May 31, 2009 | Philips Televison & Video
Unable to tune in and get picture/chanels
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
Mar 14, 2009 | Televison & Video
Got techwood 16822 tv cant find freeview chanels on it ?
I have a 168822 cant get any freeview channels is it my ariel ?
I have used and recieved freeview at my old address ?
Jan 26, 2009 | Televison & Video
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Philips DTR220/05 digital freeview reciever not recieving anymore
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Feb 23, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
199 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
