I found a Brookstone telescope at a yard sale and thought it might be nice for my grandson, but I don't know what model it is and it's missing some pieces (eyepiece for one). The only markings I see are:
D=114MM F=900MM
TELESCOPE NEWTON
Is this item worth my time / $$ to try to fix?
-   I also have a Brookstone Refractor telescope, D=114mm F= 900mm, but I do not have an operating manual. Does anyone know where one can be obtained.-   chemrxn
it's not worth spending too much, but if the mirror is in good order, it would make a fine starter scope. The very cheap and nasty scopes start around D=76mm, and often boast great magnifications, these scopes are virtually useless. The size of the mirror is the most important factor, and at 114mm, your grandson will have many hours of pleasure observing the moon and planets.
Eyepieces can be found on ebay very cheaply, but be sure to get one with the correct O/D they come in 0.96 in, 1.25 in and 2 inch. I expect your scope will be 1.25" I suggest you should buy a maximum of two eyepieces (around 30mm and 6mm) and a barlow lens. These will give you magnifications of 30X, 60X, 150X and 300X.
If you require any further assistance, please don't hesitate to ask.
Kind Regards......Dave
can you tell me if you would recommend the vivitar 60*/120* refractor telescope to look at the...
(More)
can you tell me if you would recommend the vivitar 60*/120* refractor telescope to look at the stars?
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does...
(More)
I HAVE A MICRONTA ELECTRIC POWERED ZOOM TELESCOPE 12X-40X-40mm CAT. NO. 66-203 ----- ELECTRIC DOES NOT WORK WOULD LIKE TO GET IT FIXED IF NOT TOO EXPENSIVE OR PROBLEM SOLVE WHY IT DOESN'T WORK
