Question about White Sewing Sewing Machines
Display doesn't work
The display on my sewing machine doesn't display anything. It lights up but there is no information on it. This happened to me one other time. After a week or so it came back on and worked again. I bought the machine two years ago. Do you have any ideas?
  • lisa76wis Jul 30, 2008
    No, there is no dial for the display.
  • Bonnie  Spialek
    Bonnie Spialek May 11, 2010
    Is there a dial that dims the display?
    New Friend:
  • 46 Answers
Hi Lisa,
I don't really know WHITE sewing machines but I can tell you that it might be a loose connection at the inverter. Te reason I say it may be loose is, you said it comes and goes. The vibration that sewing creates might be cause it to loosen up. It sounds like a simple fix but it might take a trained service tech to find the source.
Bonnie
Posted on Jul 30, 2008
Activa 220. freezes up
Sounds like a computer board is failing.
Sep 03, 2017 | Sewing Machines
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Jan 10, 2013 | Janome 2212 Sewing Machine
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Foot pedal doesn't work when pressed
you can either have that foot pedal checked or buy a new one
sewing machine parts
sewingpartsonline.com
sew4less.com
sewusa.com
premiersewing.com
ebay
Apr 12, 2012 | Sewing Machines
With the bernina activa 230, it will randomly stop sewing so i have to switch it off and switch it back on again. But it keeps happening, how do i solve this?
Unfortunately this could be a number of reasons, ranging from simple to hard. Taking the simple first - make sure the 2-pin plug is properly inserted into the machine - if it stops, try wiggling the plug first to see if that 'resets' the machine. If it's OK, it might be the switch on the power supply - I've had a couple that needed replacing, but in all honesty, the problem is probably internal and could range from a poorly-inserted plug on the main control board, to a component problem on the board itself, which could be costly to replace. Is your machine still in warranty (2 years on electronic parts) - if-so, get it checked-out by your Bernina service agent, just in case ... dont go messing-about with the machine yourself. Before doing this ... check exactly what happens when it stops sewing ..... I assume that the foot controller doesn't make any difference ..... check if the sewing light is still on, or the display backlight, and is the display still showing any information, or has it gone blank ? Does it happen on all patterns - straight/zig-zag etc. or a memory pattern ? This may help to identify the likely cause.
Oct 17, 2011 | Bernina Activa 130
I have a Singer Sewing Machine #9444. There is no electrical getting to my machine since the light doesn't work and the foot pedal doesn't work after I turn on the machine
Try replacing the light bulb or rerouting the wire so it won't be affected by the light bulb or the foot pedle. Becarefull though because if you rerout the the wireing in the foot pedle you're taking away the off/on swich so it'll stay on. You may want to open up the foot pedle and see if there is anything loose, not conected or broken. The pedal is used as an on/off swich so it may just be stuck in the off position and not making contact when you press down on it so it won't turn on.
If you can't fined a blulb for it by the way you can disconect the socket where you screw it in and install a new one. Make sure the new one will fit in the same hole though. Then it should be easy finding a bulb for it. PLEASE MAKE SURE THE MACHINE IS DISCONECTED BEFOR YOU DO ANY OF THESE THINGS. Good luck!
Sep 30, 2011 | Sewing Machines
I need an instruction manual for a Jones sewing machine model 865
The information did not display when I click on solve.
The best information I have is that Brother Corp bought out Jones Sewing Co in 1968. If they rebranded the sewing machines I can not tell. You can search;
http://www.brother-usa.com/homesewing/retiredmodels/retiredmodels.aspx
and see if anything matches your machine from the retired models.
Mar 27, 2009 | Sewing Machines
Open Questions:
Sewing Machines Logo
32 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
