Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Flickers on start up and very slow going to normal viewing colors and lighting
When i turn on my pc and monitor the monitor stays black for maybe 2 minutes, eventually you can see the picture dim and flickering. after maybe another 2 minutes the picture is viewable but the picture is weak. after another 5 minutes the picture is ok. but if i shut the monitor down for say maybe 5 to 10 minutes it does the same thing again. What is wrong with my monitor?
  • 12 more comments
  • Anonymous Aug 01, 2008
    on start up or after powersaver shutdown it takes a while before the screen resumes full brightness and contrast
    Don't know how to fix that.
  • milercards Oct 11, 2008
    Monitor remains black at start up, or flickers and then might eventually come on. If I turn the monitor power button on/off a few times it will usually begin to flicker and then fire up - sometimes full on, sometimes dimly, then brighten as it "warms up"
  • iron1958 Oct 26, 2008
    I have the same problem,,, description of yours is ditto on mine. If I unplug it then plug it back in (at the back it helps. I have a couple of times just tapped the back area around the power cord area ans it came back up. I am suspecting a bad cap in the power supply. At first I was thinking maybe cold solder joint, I haven't done any taking apart to look at.
  • rayefan Nov 05, 2008
    I have this same problem and it is driving us CRAZY! I have had this monitor for almost two years, I think! But, within the past couple of months this has been our problem.... AAUGH!
  • Richard4242 Nov 19, 2008
    I have the same problem only it finally quit entirely!
    Turn it on, after a minute you see it getting brighter as it flashes on
    and off. After a few minutes it gets steady but still dim. Then a few minutes later it is as good as new.... but now it is DEAD. Gone, Kaput... Nada.. zip.
    I will open it and dig in this weekend with my test equipment and
    see what I can find. If I find a single responsible part I will let oy la know.
    I assume it is a power supply issue - this looks like a bad or failing
    capacitor issue of some sort.
  • andy22nj3 Jan 16, 2009
    My monitor just started doing this, but no flickering. I just dark on startup and dim at log in, but after a few minutes it's ok. I'll check Samsung's website.
  • Anonymous Jan 29, 2009
    ditto
  • andy22nj3 Jan 30, 2009
    I called Samsung. My monitor is under warranty. I will be send my monitor for repair. It's been two weeks and I still do have the shipping label.
  • mark204b Feb 20, 2009
    There is nothing we can do to fix this, because the backlight needs replace by the factory. This monitor has been discontinued but Samsung will more than likely offer you another if yours is still under warranty as they did for me. I dont suggest opening the monitor up therefore killing your warranty. So..... the answer is the monitor is burning up and needs to be replaced by Samsung. Go to their site and talk with them and they will help you. = ) good luck. I recieved my new monitor within 1 month,,, we traded new for old over the counter at UPS.
  • Anonymous Feb 27, 2009
    Same issue - after turning on, or exiting powersaver mode, the screen is black and SLOWLY fades in, with some real flickering. It's happening more and more lately - I think it may be getting to be time to exchange it.
  • Anonymous Mar 01, 2009
    Great diagnosis and recommendation. What if its not under warranty... has anybody tried a manual fix. Probably cheaper to replace than fix anyway... I bet. :(
    I had the same problem. I replaced C110 and C111 with 1000uF 35V electrolytics. The only challenge is getting the bezel split open. Use a small screwdriver and gently split open bezel and back cover. Starting at top side and work your way down both sides to the bottom. Small cable harness is connected to front switches that needs to be disconnected.
    Monitor now works good as new.
  • kb1cih Mar 03, 2009
    I noticed my 204b was a bit dimmer, and was flickering a bit when i turned it on yesterday, but brightened up to normal after a minute or two. I've had the monitor 4 years with no problems until then.
    A few more on/off cycles have verified that it wasn't a fluke, so cracking the case will be in my future soon i'm guessing.
    A big thanks to Guest (or possibly Richard4242) for recommending C110 and C111. When it finally gets to be a problem, i'll crack the housing open and replace them. I have become a Samsung LCD fan since then and am glad it's something i most likely can fix for a couple dollars. Thanks again guys!
  • kghongaku May 11, 2010
    anyone know how to open the case? there are no screws?
FIXED: I took the advice to replace C110 and C111 with 1000uF 35V electrolytics (http://www.radioshack.com/product/index.jsp?productId=2102511). $3.18 and a pretty easy time prying open the case with a medium-small flathead screwdriver, disconnecting a few connectors, 4 silver screws (2 on the left & 2 on the right of the LCD), 2 black screws on the back of the metal case, 3 black and one brass screw on the PC board, and it works like new.
HINT: Be sure to insert your new capacitors correctly (positive and negative sides). The capacitor has + and - sides (the - side was marked on mine). The bottom of the PC board (where you apply solder) has a + marked on the positive side.
For the faint of heart: I am an inexperienced and HORRIBLE solderer and know close to nothing about capacitors, resistors, etc. So, if I can do it you can too!!!
Posted on Mar 03, 2009
Repair verified! My local elecronics supplier had the correct 1000uf caps in stock, and my 204b is good as new.
I sent my monitor back to Samsung for repair.
Posted on Feb 15, 2009
Had the same problem here !
C110 and C111 on the power supply unit are busted.
I replaced then with 2 ELCO's from 1000 picofahrad 25 V.
Voila!! runs like new.
Posted on Jan 30, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
It may be the fault of your picture tube.
Posted on Jul 28, 2008
  • Bailey's Appliance Service
    It's an LCD Flat Screen Monitor. There is no picture tube.
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
My dell E207WFP lcd first flickers and then flashes red,green, blue, black, white and green color after some time of use ...
some of the capacitors are blown on the boards that are inside the unit
the lcd is on its way out. I recomend when getting a new one to turn it off whenever you are not at your pc. even though it goes to sleep after a while of no activity there is still a current going through the unit because if you move the mouse it will wake up. I know this because I was a bench technician and I have done board level repairs. These capacitors have anywhere from a 20000 to 40000 hour life span so when not at your pc turn it off!
Nov 23, 2012 | Dell E207WFP 20" Widescreen Flat Panel LCD...
My monitor has started going black at times. If I hold down the power button, I can turn off the computer and when I reboot the monitor seems fine and I can view everything and work. Sometimes the screen...
Please try to attach an external monitor & see if you can get any display on it. If you can get display on an external monitor, then the root cause of the problems you have might be either a failing LCD backlight or a failing inverter board.
Please refer to the following article for more details on how to diagnose & troubleshoot LCD backlight & inverter board issues:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
Dec 08, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Equium A100-02k laptop black screen
sounds like it could be the monitor itself
Apr 02, 2010 | Toshiba Equium 100 PC Desktop
Viewsonic vp171s lcd flickers on start up then goes black.
This is typical of a back-light problem, especially when you view the LCD screen at a sharp angle and you see a dim Windows image. This fault is caused by either a faulty inverter board or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp. the CCFL lamp is a mini fluro lamp which fails with age and use.
This LCD screen can be repaired, the cost of an inverter board and CCFL lamp is a lot cheaper than a new LCD screen, but this is an opportunity/excuse to buy a larger size LCD screen as these monitors have dropped in price.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link to their site :-
www.lcdparts.net
Feb 08, 2010 | Computers & Internet
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Northgate Monitor - Model No. KM-718
Hi, Assuming that the monitor does not have any problem or defective components/settings, you can try adjusting your PC by: 1. Right click on any clear are of your desktop; 2. Click on properties; 3. Go to Settings tab; 4. Set your Screen Resolution to your desired size; 5. Verify that you have Highest (32bit) setting in your Color Quality; 6. Click on Advanced button; 7. Click on Monitor tab; 8. Select highest Screen refresh rate (maybe 85 Hertz) within capacity of your video card & monitor; 9. if a selection or setting does not work, pressing escape will revert you back to the previous setting; 10. Apply, OK. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Oct 01, 2007 | Computers & Internet
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
1,319 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
