Question about Apple Power Mac G5 Desktop
Number pad on iMac keyboard inactive
Number keys on the keypad don't work.=,*,-,+,work, but not the numbers. I can't find any reason for this. Can you help, please?
  • 2 more comments
  • Anonymous Aug 14, 2008
    I am having the exact same issue. My cursor is also starting to freeze after a couple of hours. I have tried (control + clear) and other remedies suggested online, but none have helped.
  • Anonymous Nov 26, 2008
    that is a common problem great solution! it worked
  • kkess2 Feb 26, 2009
    I have an imac wireless keyboard and my numbers pad doesn't work, I have tried everything that was suggested on here, Any other suggestions?
  • Arthur Keech May 11, 2010
    My first question would be whether you have checked that Num Lock is on and lit in green. The second would be do you have another keyboard and have you tested that one?
Press "clear" on the numbers pad, then the numbers will type.
Posted on Feb 01, 2009
  • drwritermom Feb 01, 2009
    Note - I have the most recent iMac (3.06 GHz Intel Core Duo), the keyboard does not have a numbers lock key, just a "clear" key where the numbers lock key should be, with NO numbers lock light.
    1,2,3.. yep, the clear button is the numbers lock for this iMacs keyboard.
  • 1,398 Answers
If the num lock/Clear key doesn't turn on the numbers, Sticky Keys is off, and you have the same problem with a different keyboard, then check the preferences for the application to see if there is a setting that overrides the num lock key. Note: in many word processing applications turning off the num lock converts the numbers into cursor control keys, so "8" moves the cursor up one line, "2" down one line, etc.
If the problem is specific to the keyboard, one of the key matrix lines (printed wiring traces) in the number section of the key membrane panel is cracked or has a bad connection to the keyboard controller chip. Sometimes you can fix a bad connection by taking the connection apart and putting it back together (you would have to take apart the keyboard first). Be careful not to touch the circuitry with your fingers - the encoder chip is easily damaged by static electricity. If you find a cracked or corroded trace on the key membrane, you may be able to patch it with silver circuit board repair compound (disconnect the membrane from the encoder board first so you don't have to worry about static discharge). The stuff is not cheap; you may decide to just get a new keyboard instead.
Posted on Jul 20, 2012
    Novelist:
    Champion:
  • 233 Answers
How old is this computer? Is it USB or ADB (Apple desktop bus)? If it ADB, the keyboard & mouse are plugged into the same inlet port. I think one going bad might affect the other. Try different keyboard & mouse. Same thing might apply to USB.
Posted on Dec 20, 2008
  • Paul Bade Jul 20, 2012
    The iMac never had an ADB input, not even the 233 MHz CRT with the tray-loading CD; it was Apple's first USB input computer series.
Try this: Apple menu;system preferences; universal access; mouse. By accident I found this (mouse keys box) was clicked ON! This disables the keyboard almost completely. it is so remote from the other keyboard controls that it is not the obvious cause. searching books was no help at all.I hope this is useful
Posted on Sep 12, 2008
  • natalie1818 Jul 12, 2010
    Thank you sooooooooo much! I've been looking on forums for ages and yours was the only one that worked for me. You are a legend!!!!
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
IMac keyboard number pad
look for number lock on keyboard.
Jun 25, 2014 | Apple 24" iMac Desktop
Apple keyboard number lock
  • Your keyboard has a Numlock Key then try to Turn it On.
  • Try a different keyboard if it is working then change your keyboard.
  • If other keyboard not working then check your system with any technician.
What is the question?
There are two types of keyboards for Mac: one comes without the number pad (wireless) and the other one does (wired). For the wireless, you can purchase a separate number pad.
IMac keyboard suddenly isn't working. Mouse works, but I can't enter any typed message.
if it's bluetooth, are the batteries ok and is it showing up in your bluetooth settings? if it's wired, try another usb port
Oct 21, 2011 | Apple iMac G5 Desktop
My dvd drive on my Apple Imac G4 keeps opening and closing on it own. What do I do to make it stop?
Sounds like a key on the keyboard is stuck. Try lightly tapping the key several times and or use a keyboard cleaner on it. Radio Shack sells keyboard cleaner
Mar 29, 2011 | Apple iMac G4 Desktop
Key dislodged on keyboard
The plastic parts you mention are referred to as "scissors." I know plenty of places who sell these parts for Mac laptops, but darned if I can find a single source of these parts for separate desktop keyboards. It's possible that the thinking is that it's really not worth expending the labor on a single key when you can buy a whole replacement keyboard for $35; whereas on most current laptops, replacing the keyboard is a major expense.
If you are determined to try this repair yourself, I recommend you visit pbparts.com and examine their laptop scissor units. Maybe you will luck out and find one that is an exact copy of your broken one. Sorry I can't be of more help.
Jan 25, 2010 | Apple 24" iMac Desktop
Disk utility won't recognize that there is a superdrive neither does system profiler there is a dvd in the imac, which i watched about 12 hours ago. usual fixes (left click restart) won't do the trick. the...
They are a few thing to try althoguht you may have already tried them;
Pram and PMU reset -
First turn off the iMac, once turned off unplug everything from the IMac and physicallly unplug it from the wall, wait about 5 mins at this point, then just plug in the very basics (keyboard + mouse) - this is the PMU or power management unit aspect of this - the next step is a PRAM or paramiter RAM reset
To do this hold down the apple + alt + p + r key on your keyboard just after you turn on the iMac, and keep these held down, you should hear it chime as normal, now if you keep holding down the keys you shoud here it chime again, keep the keys pressed down till you have heard 4 chimes in total.
After that is done let go off the keys and the iMac should restart as normal - can you eject the disk now?
Sadly System profiler is normally very effective at picking up hardware that is installed in your Mac, The fact that it is not brining up anything would suggest that the super drive may be faulty or somehow disconnected, if you try the above and it does not work then i would suggest you call a AARC or apple authorised repair center and have the S/N: Serial number of your Mac ready - you can find your local repair center on the Apple website - for example the closes repair center to me would be Jigsaw Solutions LTD (www.jigsaw24.com) who are the UK's largest retailer of Apple abode and Quark.
I hope the above is helpful and that you do not need to contact an apple authorised repaird center!
Jul 13, 2009 | Apple iMac All-in-one - 2.66GHz Intel Core...
IMac keyboard volume control keys
Do the volume keys still work when you are booted in to OS X?
Also, try reinstalling the Bootcamp drivers that will appear when you insert an OS X disk when it's booted in to Windows.
Mar 16, 2009 | Apple iMac G4 20" Mac Desktop
Apple Power Mac G5 Desktop Logo
1,792 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
