NetGear DG834G Router Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My router is DG834G v5 and it shows a red light for internet and does not connect ,there is no problem with my pone connection as the old modem is working fine, what do i do?
Anonymous
Level 3:
  • Master 1,272 Answers
  • Posted on Mar 23, 2011
Anonymous
Master
Level 3:
Answers
1272
Questions
Helped
385293
Points
3713
I understand that you are not able to connect to internet through DG834Gv5 as the internet light on the router is RED. I would suggest you to reset and reconfigure the router using the below steps:
RESET:
1. Press and hold the Wireless On/Off and WPS buttons simultaneously until the Power LED turns red (about 6 seconds).
2. Release the Wireless On/Off and WPS buttons. The LED blinks red three times and then turn green when the router has reset to the factory default state. Wait for the router to reboot.
CONFIGURATION:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
4. Access the router's GUI by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
5. Login to the router (username = admin password = password unless you have changed it).
6. Click on 'Setup Wizard' at the top of list from the left menu.
7. Select Yes and click Next.
8. It should give you 'PPPoA Detected' and then click on next.
9. Enter the login and password of the ISP and then click on Apply.
10. Once the settings are updated click on 'Router Status' and click on 'Connection Status' button (at the bottom of the page).
11. Click on Connect button.
12. Connecting to server should show 'Connected'.
13. If you receive 'CHAP authentication failed', close the 'Connection status' window and click on 'Basic settings'. Verify the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
Please do visit http://kb.netgear.com for any technical queries regarding NETGEAR products.
I hope this information allows you to resolve this issue.
Regards
Anand
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
MINE IS A NETGEAR DG834GU V5,INTERNET KEEPS ON CUTTING AFTER ABOUT 10MINS FROM REBOOTING.WHATS THE PROBLEM
There are many reasons why this might be happening.. You could try the following steps..
First connect the modem directly to the computer and see of the problem persists..if yes contact your internet service provider..if the problem doesnt show up with modem then please follow the below steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Hi im trying to connect my new wireless router netgear mod.dg834g v5 with virgin supplier.should it not be a simple connection from the existing modem into the n/gear or i didnt get a internet conn.so use...
Ya this is some what correct. You might be lacking on some system network setting. Just you have to do is make sharing of your network without any complecated authorised or password sharing. Thats it.
1helpful
I have received a netgear Dg834g v5 with no instructions, so I am trying to download a instruction manual any advice would be helpful
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Wireless light remains red after reconnecting
Purchased a I Touch ans it can not connect to my wireless network ??
1helpful
Internet light on wireless modem is red and wont connect to internet. DSL, Wireless and Ethernet port 4 are all connected with green lights. Wont properly connect the modem.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
2helpful
Do i have un install my speed touch modem to install netgear dg834v5
Hi, please note that speedtouch modem and DG834G router will not work together. Rather DG834G will replace the speedtouch modem. Remove the speedtouch modem and follow the below steps:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually http://192.168.0.1).
5. Login to the router (Username = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
5helpful
2answers
How do i password protect my router from outsiders connecting
Hi, check out the support pages here:-
http://kbserver.netgear.com/products/DG834G.asp
Select your model (v3,v4,v5 etc) then look at the setup pages. Set your security to WPA rather then WEP as this is easily crackable, and with WPA you can choose the password. You should also change the routers admin password to be extra safe.
Let me know if you need anymore help.
2answers
Connecting another router
i would'nt recommend it, theres no need for two unless you have mote than 4 hardwired pc's and 8 wireless, especially if they are both modem/routers, you cannot use two, only one modem/router and one router
2answers
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
