Keyboards fail sometimes and it pays to have a spare - I have a dozen...
As the computer boots some of the keyboard leds blink and there should be a beep from the computer showing there should be no problems. Substituting a know good keyboard is the quickest and easiest method.
Depending on the model, most just remove the top cover closest to the top of the keyboard (snaps on or off) remove the two sometime three screws, Lift carefully not damaging the ribon. Romove and replace repeat in reverse order.
hey man go in control panel-regional and language options-keybords and language-change keybords(and there change u keybord language),If this dosent work try to unistall u keybord drivers and install them again.
Sometimes viruses can trigger slow start ups. Try running your virus scan. also, you should make sure that your memory is working correctly. When you have a memory stick that has failed, its hard to tell if you have over 2 gigs of mem installed but, when you start it up, it will struggle during the process.
Reseat the keyboard: Sometimes it is possible, that the keyboard connector comes loose and thereby causing a malfunction with some keys or overall fails to work.
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
