Question about Motorola T5522 (7 Channels) 2-Way Radio
MOTOROLA T5522 BATERIES
HOW LONG TIME NEEDS TO CHARGE THE BATTERIES OF T5522 WALKIE TALKIE? WE ARE ASKING THIS BECAUSE THE CHARGER HAS A RED LIGHT WHEN CHARGING AND DONT CHANGE THE COLOR OF THE LIGHT FOR EXAMPLE IN GREEN AND WE DONT KNOW WHEN THE BATTERIES ARE READY FOR USE.
    Sergeant:
  • 250 Answers
Hello mironas3,
A general rule of thumb when dealing with rechargeable battery packs is to take the capacity of the battery divided by the charge rating of the charger and then add an additional 10%.
Offhand I am not sure what the voltage / capacity or voltage / charge rating of the battery and charger are but you can determine that by examine the labels on both items. Let’s say (for example) that your battery is listed as 7.2 volts and 1,000 mAH and your charger is rated as 9 volts and 100 mA. (These are just theoretical examples. Substitute the numbers from your own items.) You would divide 1,000 mAH by 100 mA to equal 10 hours. Then add 10%. So you expect a full charge to take around 11 hours time.
Of course, actual charge time will vary depending on how discharged the batteries are when you start charging them. Since the charger that Motorola provided doesn't have a charge indicator determining when the batteries are done charging is a matter of making an educated guess. If you touch the batteries while they are charging and they feel warm to the touch, that's a pretty good indication that they are done or nearly done charging as once the batteries are topped off excess power will turn into heat. (Note that batteries in a charger should never be HOT. If they are ever more then just slightly warm, something is wrong with the battery or the charger or both.)
Also, just a word of warning here: remember to always use the correct manufacturer recommended charger. Substituting a charger with twice the charge rate to charge the batteries in half the time is not a good idea. Rechargeable batteries are meant to be charged slowly. Fast chargers exist but they typically have built-in circuitry that pulses the charge rate to prevent the batteries from overheating. Using the wrong charger can result in damage to your battery or radio or worse could possibly even lead to a fire.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 28, 2008
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
I bought new batteries for a Motorola Radius SP21 walkie talkie but it still does work.
Here are a handful of things which could be the problem:
1. Check to be certain you have the battery installed the correct direction. With this radio, it is a common mistake to put the battery in backwards. The Motorola logo w/name should be facing forward, and with the radio in an upright position, you should be able to read the words on the battery.
2. Check your charger. The red light should come on and stay on during charging.
3. Clean all battery contacts gently with a pencil eraser to remove dirt/dust/hand oils, then try charging again. If you are using a wall plug charger only (not a drop-in) you may have a problem with the jack on the radio.
4. Check your radio to be certain it is set to the correct frequency and PL code. It must be set identical to your other radios in order for them to communicate with one another. If you need help with this you can give us a call at 800-872-2627, and we'd be happy to walk you through SP21 programming over the phone.
Best regards.
Sep 26, 2014 | Motorola Radius Vhf Sp21 2 Way Radio...
Ive got a set of Motorola t5522 walkie talkies,but have not got the operating instructions
You will find the manual here: www DOT giantintl DOT com/ContentManage-new/manuals/Moto/T55xx DOT pdf
Best regards
Sep 03, 2013 | Motorola T5522 (7 Channels) 2-Way Radio
What will happen if i overcharge walkie talkie for 3 days?
You will age your batteries some, by them being left on the charge. However, for a weekend or 3 days on occasion, you will cause no serious damage. However, if you were to leave them on an extended time, say 10-30 days, you could conceivably "cook" the battery and cause it to fail.
Many modern chargers have a safety feature where they will go to trickle charge after a battery is full.
Best regards.
Feb 10, 2012 | Motorola Walkie Talkie 2-Way Radio
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
The battery is flashing red when charging
You do not mention which model of Motorola radio you are charging, so this will be basic information: Typically if a charger blinks red when the battery is initially put on the charger, you either have:
1) Dirt contacts. Solution: Clean with pencil eraser, both radio and charger contacts.
2) Shorted or bad battery. Solution: Replace the battery.
3) A bad charger. Replace charger.
Some simple troubleshooting might determine your problem. Try the battery on a different charger and see if you get the same blinking light. If so, you have a battery issue. If the problem disappears when you place it on the known good charger, then you know you have a charger issue.
Best regards.
May 17, 2011 | Motorola Walkie Talkie 2-Way Radio
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
I need a user manual for the Motorola T5522 two way radios/walkie talkie. Please can you help me find one?
Here is a link: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf Have a nice weekend.
Jun 05, 2009 | Motorola T5522 (7 Channels) 2-Way Radio
Charging
put batterys in a normal charger. if still nothing,. problem lies with radios.
May 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Motorola T5522 (7 Channels) 2-Way Radio Logo
399 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Iron
Iron
OBHighflyer
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
