Question about IBM Computers & Internet
Location Port LPT1 - IBM Computers & Internet
  • IBM Master
  • 19,396 Answers
At the back otf the computer, is the large pink socket in the picture below:
Posted on Jul 28, 2008
Adding a brother printer to a hp2000 with 3 usb ports
USB ports create a virtual prot for USB-based printers, example; USB001, USB002, etc. It will not be LPT1.
May 13, 2014 | Lenovo H430-2558-1CU Desktop PC
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
LPT1 error
LPT1 is probably your default printer port assigment. I would re-install the factory software to see if that clears it up. Your printer probably came with CD - use it to reinstall the printer.
Oct 15, 2013 | Kodak Office Equipment & Supplies
Where is LPT1 USB port on Lenovo H430 for printer
Few computers use LPT1 connections, most use USB .Use a Printer cable with a USB to laptop. Your printer should have a cable that has a printer connection to a USB laptop connection? What is the Printer?
Dec 13, 2012 | Lenovo H430-2558-1CU Desktop PC
Error LPT1
This is the communication port with which the cable plugs into instead of using for example an ethernet port. Not sure what you are meaning with just the reference LPT1 but this is simpl;y the port the cable plugs into
Sep 13, 2011 | HP LaserJet 4 plus Printer
Scanner driver for cannon ir3300 connected to lpt1 port
Canon Network ScanGear only works over an ethernet connection. There is no scanning available via LPT1 port.
Dec 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Cant load driver in port lpt1
AN IEEE 1284 port is a parallel port protocol. Lpt1 is a physical port on the PC that attaches to the printer.
Basically, the PC is telling you that it expects the printer to be connected to the LPT1 port on the printer and that it is expecting the printer to be conversant with the IEEE1284 protocols.
Given what you have described, you should not be having a problem connecting the PC to the printer.
Please let me know what the exact failure is and the make and model of the printer that is causing the communication between the PC and printer to go "Toes Up."
Don
Dec 11, 2009 | HP OfficeJet T45xi All-In-One InkJet...
LPT1 not working
Hi looking at your description it seems more like a drive error as a opposed to lpt1 problem, I've never known a lpt1 port to stop boot.
Sata drives are notorious for bad connections, could it be that the connections to your drive have worked loose?
I hope this helps, if not please let me know thanks.
Jan 05, 2009 | IBM ThinkPad T60 Notebook
My Printer EPSON TM-U220 does not print....HELP!!!!!
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Jan 14, 2008 | Epson TM-U220 Matrix Printer
Printing,hp deskjet3420
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Computers & Internet
Computers & Internet Logo
102 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
