Question about Refrigerators
Indesit ban12nf fridge not working,freezer is ok
Itmeans that the frees\zer compartment has been overfilled. Defrost it for 24h (all doors opened) and clean it, that should solve the problem.
Posted on Jun 08, 2010
I have an indesit fridge freezer and its only 8 months old and the freezer part is starting to freeze where i cant hardly open the shelves otherwise the rest of the fridge freezer is ok what can i do
-Remove every thing you have in there. Open its door and then unplug the power cord. Leave it open and unplug for 1 day or until all ice melt down and then clean up. (Do Not use any shape edge like knife, screws driver to scratch or remove any ice! It'll damage the Freon system.) If the shape object need to be used then you'll get NEW Fridge soon.
Dry it up and then plug back again.
-Make sure set the temperature knob to normal Only. (not the coldest) This will eliminate to build ice faster than normal.
Good luck
Mai
Jan 24, 2017 | Indesit Refrigerators
Fridge freezing food adjusting thermostat make no change
Sounds like the vent is stuck open on your model. Here is a service bulletin for your model=> HERE
APPLIANCE 911
Dec 14, 2015 | Indesit BIAA134 White 292 l Fridge Freezer...
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Why freezer not working on indesit fridge freezer
is your fridge working or is the compressor running.
May 27, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge/freezer starting & stoping
The compressor is supposed to start & stop, it wont run all the time.
Nov 22, 2013 | Amana ABB1927DE Bottom Freezer...
Please help my indesit ta 5 fnf s is dead with no warning. no lights no power nothing. its not fuse power or socket
Had the same problem with my TA5FNFS once you have confirmed as there is power in the wall socket and the fuse in the plug and cable are ok, I found as the PCB control board had burnt out costs about £60 for a replacement board
Apr 30, 2009 | Freezers
My indesit freezer in on amber light on 1 and it is too cold should the light be showing amber
check to see if you dont have unit on quickfreeze.or possibly the thstat is set to high or control is faulty
Jan 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
626 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
