Mine stopped on last spin when we had a power cut. Now it will not finish cycle or start a new one. What is wrong?Mine stopped on last spin when we had a power cut. Now it will not finish cycle or start a new one. What is wrong?
You can't post conmments that contain an email address.
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+... iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl... Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty. check these one by one.
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Had a similar problem ,flashing red led means door not locked, I
removed door from machine removed front from door and found hinge pin
for lock had come adrift, religned pin and chapped back into position
.THen replaced door and door to machine .dor shut and lock worked
perfectly, hope this helps If this doesn't work you may have to replace the EMW. Should cost you around 60$
