Question about Bosch Washing Machines
Bosch model WFF1401 : Noise like a Boeing 747 @ top speed @ the end of the spin cycle otherwise all noises sound normal and no effect on washing performance. Main drum bearing failure??? Easy to mend ? Very competent DIY Noel Fay
  • mingi31 Aug 29, 2008
    hi
    i have a bosch waa 24160gb/1. and this is like a jet taking off, i think its the drum bearing, what re they like to do, is there 1 or 2 in there,
    cheers
    Novelist:
  • 116 Answers
This usually indicates that there is an issue with the motor or rear bearing. This can be isolated by first removing the power from the machine the removing the inner rear panel from the machine. You should be able to see the belt and motor. You can spin the belt off easily then reapply power and place the machine in a spin. Keep clear of the motor as is spins around 18000 rpm. Let the motor stop and remove power from the machine. You can spin the inner tub by spinning the large pulley by hand, if there is a excessive noise or grinding feel then the bearing will need replacing. The belt can be spun back on and the machine run with the rear cover off but again be very mindful as this cover is there for a reason.
In most of the cases the moise is from the motor itself. There are rebuild kits available but they are mostly a waste of money. The motor if worn should be replaced. They should carry a multi-year warranty, check your manual.
Posted on Jul 28, 2008
How do you access between the drum and plastic outer casing? Trying to remove a bre wire from within.
remove the four screws that hold the whole top on two might be under plastic caps then you can see the ring which covers both bowls which is either clipped or screwed into place remove thatand you can then see
Dec 01, 2017 | LG Washing Machines
Bosch classixx wvf 2402 at the end of the dry spinning cycle, 5-6 minutes the machine makes a terrible noise. What could this be?
Can you describe the noise? Is everything else working normally? From what you are saying, my guess at this point would be that the pulley on the motor is working loose.
Jun 13, 2014 | Bosch Classixx WVF 2402 Front Load...
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Washing machine
Here is what I suggested to another person with a similar request......
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or break motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty. When you close the lid again, you will hear the solenoid release the drum, and then the motor starts spinning the drum again.
If that is the case, it is normal and no need to worry about it. However, if you did not have the noise before, then best to get a repairer to check it out.
Regards
Ash
Nov 08, 2009 | Washing Machines
My washing machine makes a cluck sound at the end
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Nov 07, 2009 | Washing Machines
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
335 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
