I recently bought a matsui air conditioner model no: MPA9KWR..after one month of using it had let out 1 cup of water through the water out let.,but last night the system started to drip water constantly...what am i missing? it is still dripping and ther eis no water coming out of the water out let...please help...mail me sudha_gmc@yahoo.com.
I also have this problem is there a solution to this
Posted on Sep 08, 2009
My water container has black fungus ,Icould'nt clean it and I'm afraid to use it.
get a filter from repeatable store.. if i may where's one i recently bought one works good.
Water Treatment
Jul 17, 2016 | DeLonghi Pinguino PAC-700T Air Conditioner
Sharp Air Conditioner Model AF-G501CM
if it is cooling properly I would not worry about it.AC unit should sweat if it is hot outside but depends on the humidity level.usually if it is real hot and it is not sweating it is low in freon.
Apr 22, 2012 | Heating & Cooling
Water leaking out of frigidaire portable air conditioner at left back bottom corner? Model FAPO94P172 or FAP094P172??
First, have you drained the tank recently. If not, the warning light or auto shutoff failed and the tank may be overflowing. Worse case scenario is the that the tank is dirty and is not allowing the coils to cool and the dripping water you see is from the cooling coils. Since the tank is not removable, it's very difficult, at best to clean the tank.
If you drain the tank and before reinserting the drain plug, try to get about 1/2 teaspoon of bleach in the drain hole. followed by 2 cups of water. Of course you'll have to use a funnel of sort to do this. Reinstall the drain plug and move the unit around so the water and bleach will slosh around. Then run the unit until the bucket is near full again and drain it thoroughly. Look at the color of water draining out, for an indication that there is dirty water. That will be a good indication, that some cleaning of the tank has taken place.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Frigidaire FAP094P1Z Portable Air...
I recently bought the latest model of keruig and after only a month it barely drips now. the water only dribbles out. I am not sure what to do.
Hello, W/D here.
Take an ordinary paper clip, and bend (unbend) it into an "L" shape. Use the end that is about 1" long to pass up into the K-cup puncture needle, and down into the outlet needle. Grounds can migrate in both directions, and this may be the problem. If this does not correct the problem, go through the de-scaling procedure, and clean the needles again after the de-scaling process has finished.
--W/D--
May 31, 2011 | Keurig B50 Coffee Maker
Air Conditioner (RUUD model: UBHC-14J06NFD) is leaking water from bottom. It is causing a major puddle in Air Intake area.
The condensate drain line/pan is clogged causing the condensation to overflow the pan.
The easy way to fix that is attatch a powerfull wet/dry shop vac to the end of the drain line and such out whatever is causiing the clog. Also take off the panel to the evaporator coil and clean out the pan with the shop vac.
To double check that the clog has been removed, pour a gallon or two of water into the pan and ensure that it is draining properly.
Oct 11, 2009 | Heating & Cooling
Bubbling water sound in AC. Water in the tray is cold. Unit continues to make a gurgling sound.
The gurgling sound is the liquid refrigerant going through the refrigeration copper lines , it's normal. And the water in the tray is condensation and is cold because is from the circulating air that gets cold going through the air handler(inside unit) You only has to keep the drain clean ,by pouring 1/2 cup of clorox every 3 or 4 months.
Sep 25, 2009 | Goodman Heating & Cooling
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
I just bought a Commercial Cool air conditioner, model number CNP12XH9 and have to maznually drain the water (approx 1-1/2 cups) every hour or so. Is thisnormal?
no there is supposed to be a drain tube that goes outside you have to plumb it in, there should be a plug or fitting in the catch tray for the water.
Jul 28, 2009 | Heating & Cooling
Carrier Product # 38BRC042320
This unit was manufactured 1/8/00 and is a 4 1/2 system
Sep 30, 2008 | Carrier 38CKC036 Air Conditioner
How to use
2 cups of water poured into the reservoir. 1/2-1 cup sugar in the sugar chamber-spread evenly. refill pitcher with 2 cups water and ice to ice line. turn on lemonader and juice 4-6 lemons. When unit shut off, stir juice and serve
Jun 15, 2008 | Salton LM8 Lemonader Citrus Juicer
Heating & Cooling Logo
437 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
