Question about Refrigerators
My LG GR-P197WVS 569 litre keeps beeping randomly and at times rapidly, but it is the ice dispenser area, not the door. The beeping is the noise that it makes when you change the selection from water to ice or crushed, not the open door beep. I have tried turning the fridge unit on and off as well as locking the selection panel, but it will still randomly beep.
5 Suggested Answers
jeffbvegas1
  • 520 Answers
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Posted on Jun 28, 2009
woodchuck789
  • 4059 Answers
SOURCE: LG fridge freezer GR-L207QVJA.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Jul 01, 2009
SOURCE: Crushed vs Cubed
The solenoid itself might be all right, but just can't move the plastic piece because it's stuck and needs to be defrosted and a bit of grease applied to the plastic slider. That's what happened to ours.
I posted a solution here, but it's not the easiest maneuver in the world to actually disconnect that harness to remove the dispenser.
You might just be able to shoot a bit of grease back there, from the front, without removing the dispenser, and then work it really good back and forth to free it up. Better yet, take a hair dryer and first defrost that plastic selector mechanism, by blowing hot air on it.
Also look at this, where I talked about removing the entire dispenser and defrosting, drying, lubing a couple of points in there --
http://www.fixya.com/support/t651511-ice_dispenser_not_dispensing
Larry
Posted on Jul 17, 2009
woodchuck789
  • 4059 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
Posted on Aug 17, 2009
Sea Breeze
  • 4654 Answers
SOURCE: MAYTAG ZIG-ZAG FRIDGE-FREEZER WANT DISPENSE WATER
Sounds tome that there is a short in the dispenser control circuit, keyboard or Control Board. If you had the model number I could help you better than this. I possibly would be able to walk you through this, Let me know, Sea Breeze
Posted on Nov 19, 2009
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
LG fridge freezer GR-L207QVJA. The ice dispenser gives a choice of crushed ice or ice cubes, but has stopped dispensing ice cubes and gives crushed ice on both settings.
Jul 01, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Water dispenser lg gr-602tvpf
I also have the same problem. No water but the ice maker works.
Jan 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from dispenser
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Dec 17, 2007 | Kenmore 25.1 cu. ft. Side-By-Side...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
