Question about JVC AM FM CD DET FACE CAR STEREO
JVC car stereo KD-G645 stop working(sound muted) when horn was pressed but display and power are k( ON),
JVC car stereo KD-G645 stops working(sound muted) when horn was pressed but display and power are k( ON), what could be the reason
  • freemanspage Jul 30, 2008
    my car stereo will give you sound for 5 seconds and then the sound will go away what would cause this problem?
5 Suggested Answers
SOURCE: JVC KD-G720 car stereo - how to change the time?
disconnected the battery an lost all the stations got them back now i can't get the time right  HELP?
Posted on Sep 30, 2008
  • 4 Answers
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
Posted on Mar 01, 2009
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
  • 13 Answers
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
Posted on Apr 22, 2009
I have a JVC KD-R80-BT it is one week old and when it s cold outside the clock stop working
I had the same issue. I found that this is normal system function for one of the three clock displays. This will only affect the large clock display. When the unit is too hot or too cold, a symbol LT will appear on the screen in the upper right corner. When LT disappears, the unit temperature is at a satisfactory level and the clock will function normally. In the manual, it says that displays is frozen until the unit heats up or cools down because scrolling would be fuzzy.
Jan 27, 2013 | JVC KD-R80BT AM/FM CD/MP3 Car Stereo...
Jvc cd player model kd-g120,how do i set the time?
Press and hold 'SEL' press down arrow until CLOCK H is displayed rotate Volume knob to adjust press down arrow once to display CLOCK M rotate Volume knob to adjust press 'SEL' to finish. Reference pages 6 and 10 in this link to your JVC KD-G120 Instructions Manual.
http://resources.jvc.com/Resources/00/00/91/GET0330-001A.pdf
Nov 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
My radio will not work
for turn off this radio press power botton for 3 second. if you press only with one touch is for mute. turn on press one secon---turn off press 3 second---1 touch is mute.
Sep 09, 2009 | JVC KD-G140 Car CD Player
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
KD-LX100 working fine, then CD sound stopped working.
That particular cd might have been damaged .
Have you tried with any other cd .
Nov 27, 2008 | JVC KD-LX100 CD Player
JVC KD-G200 won't power up any more.
Have you checked the fuse-box to make sure that you didn't blow the fuse for the radio? Also try removing the radio and checking the wiring to ensure that it is tight. There is also a fuse on the back of most radios to check!!
Nov 16, 2008 | JVC KD-G200 CD Player
Important.!!!
JVC KD-AV7010 200$ JUST MONITOR AND POWER CABLES NO BRAIN BOX WORKING GOOD
Sep 06, 2008 | JVC KD-AV7010 DVD Multimedia Center Car...
JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Aug 21, 2008 | Car Audio & Video
Press and hold the SEL button to bring up the settings menu. Press and release the tuning (>>>) buttons until you see CLOCK H. Turn the volume knob to select the hour. If necessary, press (>>>) for CLOCK M; adjust the minutes setting with the volume knob. Press SEL when you're finished. An owner's manual can be downloaded from JVC at this link: http://books.jvcservice.com/booklist.asp?Model=KD-G720J
Mar 15, 2007 | JVC KD-G720 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
403 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
