Question about BenQ FP71E 17" LCD Monitor
Flickering then off
The monitor flickered then went dark. when i reboot, the BENQ logo on a purple background is visible for a few seconds then the whole screen goes dark
  • 2 more comments
  • dottybern Jul 28, 2008
    hope you can help
  • Anonymous Aug 31, 2008
    me too
  • Anonymous Sep 21, 2008
    me aswell
  • theforemans Sep 26, 2008
    Help have same problem. Anybody fixed it yet?
    Champion:
  • 220 Answers
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Posted on Sep 20, 2008
My BenQ G2220HD Monitor flickers. I've tried my level best to solve this problem but could not get rid of the flickering.
Try connecting it to a different laptop/desktop, to see if the flickering "follows" the monitor. If not, then the video-card in your computer is the problem -- try connecting another monitor to your computer, to see if the flickering still happens.
Sep 02, 2010 | BenQ G2220HD Monitor
BenQ fp567 goes on a flicker mode and will not respond
The fault could be a faulty inverter or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp, if faulty the CCFL lamp can flicker or not light up. The CCFL lamp is a mini fluro lamp, and flicks on and off when faulty especially as it ages.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Oct 01, 2009 | BenQ Computers & Internet
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Screen flickers and then turns gray
Access BIOS and test if the flickering continues.
If not, it is a Software problem, do a full system recovery
If yes, it is a hardware issue, better contact Toshiba tech support to have your LCD repaired if you are still in warranty.
If your not in warranty, you need to check out the LCD harness that might have been loosely connected.
Hope this helps...
May 12, 2008 | Toshiba Satellite A135 Notebook
Monitor Flickering
If you have some electrical equipments like CVT, UPS near to your monitor, please put them away. If the flickering is due to the maganetic interfearence then it will solve your flickering of screen. and even after this if you are not able to use your monitor buttun then please call your technical expert b.coz your monitor may got some physical problem.
Thanks
Iqbal
Mar 08, 2008 | BenQ FP567s 15" LCD Monitor
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
BenQ FP71E 17" LCD Monitor Logo
391 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
