Question about JVC KD-G120 CD Player
No sound!! I installed evertything correctly even speaker wires but i get no sound!
Http://resources.jvc.com/Resources/00/00/91/GET0330-001A.pdf
Page 13 is the trouble shooting for this.
Posted on Feb 03, 2009
I have a pioneer 2din deck and it sounds bad. it sounds like the speakers are blown and makes a crackling sound. I have replaced the speakers and it still sounds bad. I don't even have a amp
Make sure the positive and negative wires for the speakers are correctly(not reversed) and securely attached to the mounted speakers and the speaker outlet wires on the deck
Jan 16, 2015 | 2000 Ford Ranger SuperCab
No sound from speakers after installation
despite your assurance on correct installation, I'll wager you have your speakers wired in reversed polarity, in direct opposition to diode based voltage spike filtration, hence no sound.
Jul 04, 2014 | Pioneer DEH-X8500BS
Speakers not working
Check the easy stuff first: make sure the volume is at a reasonable level and play sounds from multiple sources like pandora, youtube, a local mp3 etc to make sure issue is consistent.
Next make sure the one or more wires are plugged into the correct ports. Or at the very least the green wire is plugged into the green plug on the computer (unless they're USB speakers?).
You could always look at the sound settings of Windows and see (if your sound card has multiple plugs) if the plugs and assigned different functions (base speaker versus microphone/headphone etc.). Hope this helps!
Jun 03, 2010 | Logitech X-530 Computer Speakers
No sound is coming out from my toshiba laptop. even external speakers are not working. is it a problem with the soundcard?
check first the driver you intalled the driver but maybe this is not his driver because sometime can installed any sound driver but not working be sure that driver you installed is correct or try to update then if not working also check then wire connection of speaker,then sound card.
Jun 11, 2009 | Toshiba Satellite A10 Notebook
Check the audio settings in your Kenwood consult the manual.
May 08, 2009 | Car Audio & Video
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
Installing 4 after market speakers in my Ford F-350. POS/NEG post
this is actually a quotation from a site on the net as i've wondered about it to
"Speaker wire has a mark or strip on one of the conductors this is to indicate polarity of the wire. When installing speakers to the output of an amplifier you need to observe the proper polarity. This is particularly important when installing a surround sound system with front and rear speakers. If the polarity is not followed then the results will be poor balance of sound and even cancellation of some frequencies."
Robert
Jan 21, 2009 | 1994 Ford Mustang
Ihave a JVC G230 and there is no sound
you have one speaker that has a short, a good way to find it quick is turn radio off and on if any of them pop even the slightest that is where your problem is...if you dont hear a pop check that all wires are not touching a ground somewhere this send the unit into protection, just one speaker or wire will do this .it keeps the radio from burning up...
Nov 27, 2008 | JVC KD-G230 CD Player
JVC KD-G120 CD Player Logo
74 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
