When plugged in the screen displays"1P:C8" and no button pushing will change this reading. How do I turn the radio on ???Ran great for years until power glich. Looked for op manual,but no luck. Thanks
I had the same issue. The fix for me was taking it apart and spraying the circuit board down with contact cleaner. My guess is that I ran a humidifier in the room and the humidity caused resistance on a resistor changing by the value.
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer! You can find the radio code at: http://www.radio-code.co.uk/
The sequence of Audi radio programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
The sequence of programming for 2001 Volkswagen Golf radio is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
My Coby CRA108 starting doing this after 6 months of use. Although I described the display as 1P:C8 since there is no key to properly display the character (hybrid of a G & C). I've left it unplugged and changed the backup battery with hopes it would reset. No luck so far. Anyone have success???
after you put in the code for the radio try turning the radio on by hitting the power button. there might also be an eneter button that you can push as well.
In order to solve this issue, please do the following:
Unplug the power cord of the BOOM
Push and maintain the button 1 on the Squeezebox player
Keep maintaining 1 and plug back the power cord
Release 1 when you can see RESET DAC
Fixed ! Have a great day ! J -
turn the bike ignition on or to accessory, then turn radio to off. You will then see a sreen with the word set on the lower right. Next locate the buttons on the far right of the radio. Find button number 6 and push. Now you will see a screen with the clock in the middle and on the left will have hrs+ and hrs- and on the right you will see min+ and min- . Push the buttons next to desired function. For example if the clock is displaying 4:10 and it needs to read 5:30 then push the hrs+ button once and push the min+ several times until the 10 changes to 30. When the correct time is displayed turn your bike off. Now turn the bike on and turn the radio on, walla! you should have the correct time.
