Question about Bosch Dryers
When a load is added to dryer the dryer has difficulty starting to spin, this problem has got worse, now it will only start if there is only a couple of items in the drum (2kg) any more and the motor just growns? It's almost as if it just needs that initial jump start to get it spinning. Once dryer is spinning it is fine?
    Novelist:
  • 116 Answers
The typical motor has to elements to it. There is a start winding and a run winding. The start winding supplies the initial kick that your machine is missing and the run winding supplies the running power. In some cases the relay on the motor itself can be adjusted to allow the start winding to perform its function. In most cases the entire motor will need to be replaced.
In some rare instances there have been misshapen blower wheels which cause excessive friction on the blower housing which in turn mimics a bad start winding.
To make a long story short the changing of a motor on the Bosch dryer (either the large dryer or the small one) is fairly involved and you should have a professional check it out.
Posted on Jul 28, 2008
Spins real slow with a load. seems to spin ok when empty
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2011 | Dryers
I have a samsung front load dryer. It shut off during the middle of a load of clothes. It turns on but does not spin just makes a buzzing sound?
heatman101
Aug 18, 2011 | Dryers
With a full load the drum wont spein. but spins good with no load
heatman101
Jul 07, 2011 | GE Profile Harmony DPGT750EC Electric...
HI MY AMANA DRYER HAS A HARD TIME STARTING AND AFTER A FEW MINS. STOPS
I am a little puzzled! Normally the difficulty is with startup rather than stopping after starting. Are you sure that the drum actually turns or maybe it just sounds like it is turning? If it never actually turns then it is probably the belt or the motor. You can make sure by placing only a few items in the dryer (try a couple towels or different colors) place the towels inside, (pay attention to where they are) begin the cycle, open the door to see if the towels have changed position. If the drum has been rotating then try adding a few more items to see if things change.
If the drum does not turn at all it maybe the drum belt. If, as you increase the load, the drum has difficulty starting then it is probably the motor or a control circuit. Hope this helps...Good Luck. Douglas
Jan 28, 2011 | Amana Dryers
Spin dryer won't spin.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 12, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Dryer MDE 4916AYW: Drum doesn't spin, makes buzzing sound when drying avergae size load works fine if put in small load
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 15, 2010 | Maytag Dryers
Drum not turning on spin cycle but i hear motor spinning
heatman101
Nov 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer is not spinning on a full load not even on a medium load
heatman101
Nov 04, 2010 | Amana DLE330RAW Electric Dryer
I dried a load of laundry in my dryer. Took it out and added another load. The dyer would not start. The door switch appears fine. What else can I check?
heatman101
Sep 25, 2010 | Dryers
MY FRONT LOAD DRYER IS EXPERIANCING DIFFICULTY IN TURNING THE DRUM WHEN STARTED. UNIT WILL TURN ON, HOWEVER THE DRUM MOVES VERY SLOWLY OR NOT AT ALL. PROGRESSIVELY GETTING WORSE!!! ANY IDEAS????
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Either bad motor or loose belt...
heatman101
Aug 31, 2010 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
59 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
