Question about Zenith B27A11Z 27" TV
The coax cable connection on the back of the tv
The connection for cable in on the back of the tv has broken off. But could I just pick of a rf modulator to make it work?
  • 374 Answers
Absolutely if you have additional inputs to the tv. You solved the problem yourself.
Have a great day and rember you have to find the proper input that you connect to to see image.
Posted on Sep 09, 2008
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
I dont know what chords to use to hook up a dvd player to the pfm-42v1 tv. the tv doesnt have a yellow, red or white connection
Hello bobbylanetra,
if your tv does not have the composite connection (the red, white and yellow), I am going to assume that you have a coax in though. So what you should do is get an RF modulator. Connect your dvd player OUT to the RF modulator IN with the composite cable, then use a coax cable and connect the RF modulator OUT to the coax IN of the tv. That should solve your issue. I hope this helps or if not give me a feedback, good luck.
- Joe
Aug 31, 2011 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I am trying to connect my NES to my 40" Dynex HD TV through the AV cables and the tv says no signal but i unhooked the HDMI cable and tried the AV cables for my xbox and the xbox worked fine. How can...
  • Well the XBox has it's own AV cable pack it uses. The AV cords you are using for the NES are a separate set that are apparently bad. So to play using the AV cords you just need to pick up a new $2usd pair or see if you have a pair laying around the house.
  • You do have a coak input on the back of your TV so if you have an old coax cord laying around the house you can use the RF bonx that cam with the NES. Hook the coax from the TV to the "OUTPUT" side of the RF box and then run the little RF cord to the NES. Then turn the TV to channel 3 or 4 and you can play it that way.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 21, 2011 | Video Game Consoles & Games
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
My 42 inch sylvania plasma tv does not have a coax connection, so how do i hook up my cable to the audio/video connection? i know there is an rf converter to transfer audio/video to coax but i really...
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Aug 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Why won't my tv pick up any cable channels?
If you have the cable box connected through the coax or RF connection on TV. (from the wall to the input of the cable box and output of the cable box to the in or RF in on the TV). Then in the menu on the TV you need to select the input source. It will say cable(CATV) or antenna. You should be set on cable.
Jul 18, 2009 | Proscan Televison & Video
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
Coax that looks like RCA?
There is a distinct difference between coax and phono (rca) cabling. Coax, sometimes called RF, is a cable that carries audio and video at the same time, what we call a "modulated" signal. RF connections look as if they are threaded on the chassis of your TV or VCR etc. A lone "Phono" cable moves either audio or video, but not both at the same time, unlike coax.
If you are attempting to patch RF, your cable must be coax at both ends.  Hope that helps.
Jan 07, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
I broke off coax cable on back of 32 inch tv. I can watch dvds with AV cables but not cable TV. How do I connect cable from wall to tv if coax is broken off
This depends on how many available inputs you have on the back of the set. If you have more available you can just hook up the cable box composit (yellow, red, and white cables) if not you will need to replace the rf connector or tuner in the set. let me know if you need more help.
Sep 11, 2008 | Televison & Video
Zenith B27A11Z 27" TV Logo
52 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
