Question about Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher
Circuit board? Hi: Where is the circuitboard located? What do I need to unscrew? Thanks Julian
    Genius:
  • 1,226 Answers
Please refer to the user manual, That is near the input power.
melnavz
Posted on Jul 29, 2008
How to replace main circuit board
The circuit board is normally located at the back of the appliance, behind the metal grid along the bottom, unplug the appliance, unscrew the grid and the PCB mount, disconnect the pcb and swap with new one, then reassemble
Apr 10, 2014 | LG LRSC26930TT 36" 25.5 Cu. Ft....
Cannot set program
Try resetting it by disconnecting the power cable, but at a glance looks like the programmer is faulty.
Jul 28, 2008 | Smeg 18 in. STX45-1 Stainless Steel...
Double Horse 9053 Volitation Gyro cuts out
Most likely a fault with the PCB circuit board and needs replacing. Also check the motors and rotors are running freely as this could also cause the PCB to trip off.
Kind regards, julian.
rccontrolfreak.co.uk
Dec 18, 2013 | SYMA Toys industrial 9077 Double Horse...
Speed changes on it's own and sometimes it only has one speed. wondering if it is the motor or switch?
Neither the circuit board need jacking up with a washer either side or worst case a new Circuitboard.
Apr 25, 2011 | Andis AGC2 Hair Trimmer
Model ghw9150pw the code comes up as code f 11
Hi, I've had that same problem. The problem is the CCU circuit board inside at the top, back of the machine. There are cold solder joints on the circuit board where the relays and spade connectors are supposed to be soldered to the underside of the board (poor quality control at Whirlpool) You'll need to remove the circuit board and have the spots touched-up. The inputs to the circuitboard housing are keyed but it's still best to tag which wire goes where. You will break a few tabs on the housing when you take it apart (poor plastic choice by Whirlpool) It's best to remove the entire assembly then take the board out when your at the table cursing Whirlpool. If your up for the task great! if not, just print out this response and have a service person do it or take out the whole assembly and let a good appliance repair shop do it, it's up to you. This repair will also take care of an FdL code. Once the board is out the repair takes about 15 minutes. After completing mine the machine hasn't missed a beat in two years. Good Luck
Dec 01, 2010 | Whirlpool Washing Machines
2001 honda civic air conditioning
This is a simple fix, in fact, you can fix it for under a dollar if you've already got a soldering iron.
You need to unscrew the panel underneath your glovebox and then unscrew the blower motor mount/controller. Once it's unscrewed, take the controller circuitboard off. You'll see a thermistor on one end that needs to be replaced. You just solder a new resister (1ohm) to the other side of the board between the two solder points where it comes through the board for the original thermistor. If you're up for the work or know someone that can do it for you, let me know and I can write a tutorial and walk you through it. It's a simple fix and only takes about 20 minutes or so to do.
If you'd rather not do the work yourself, the part from honda is about $150.00. (US)
You can reach me at e_z_minded_guy@yahoo.com or just reply to this post.
-Chris
Jun 22, 2009 | 2001 Honda Civic
SGH C160 DEAD
Get a new one... or you could tell people what the actual problem is that might help
Jun 06, 2009 | Samsung SpinPoint P80SD 160 GB SATA II...
I have a double horse 9083 and i cant seem to control it i have adjusted the tail rotor and still nothing.
Hi, Does the tail motor run freely (nothing wrapped around the motor shaft) if so have you adjusted the potentiometer on the circuit board. If niether of these work I would say you have a faulty circuit board.
Regards, Julian.
www.stores.shop.ebay.co.uk/GADGETSNTOYS-UK
Jan 03, 2009 | Axial Syma 9086 Helicopter
Rca F32450
I CANT SIRSH THE TV
May 31, 2008 | RCA F32450 32" TV
Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher Logo
161 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
