Question about Motorola Mobility RAZR V3
Razr keypad for some reason some of the keys on my keypad do not work specificly the down button and the 9 key, and if i do press these buttons the keypad dims... any suggestions on how to fix this?
  • 5 Answers
Its a simple problem and i dnt tink u will b able to do it.the main bord is connected 2 da key pad wichs also conects to da lcd.so basicly ur ribon is damaged.it cost about 150rand to repair.
Posted on Jul 28, 2008
SOURCE:
How to turn off text clicking
REDUCING KEYPAD VOLUME
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Mark
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
Keypad acting up!
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Sep 27, 2008 | Motorola Mobility RAZR V3
Keypad does not work
I had a common problem which none of my keys worked except the "off" key. I baked my phone in the oven on the lowest setting for 20-30 minutes and it works now. It is a humidity issue.
Mar 16, 2008 | Motorola Mobility RAZR V3
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Keypad
open it ang change if u dont want to change open keypad circuit and clean it with eraser.I AM SERIOUS.
Nov 24, 2007 | Motorola Mobility RAZR V3
Front cover buttons not working
has this area been wet at any stage?
Nov 01, 2007 | Motorola Mobility RAZR V3
Keypad troubleshooting
when I open my phone it seems to be stuck on the right arrow button so it goes to "IM account". I was really confused this morning because even if I click exit, it goes back to the same thing on its own. when I get a chance to press menu, it just whirls around as if I'm pressing the arrow over to choose a category but I'm not.. its weird.. probably the weirdest phone I've ever had
Sep 23, 2007 | Motorola Mobility RAZR V3
Stuck buttons?
Yea dude, my piece just started having that problem. It seems like the buttons are stuck, or like some presses them and such. I can't check my text's or look at my menu or nothing when its doing it cause my 9, 6, and 8 button always pop up or act like there being held down. Well,I don't know how you got this problem but mine showed up after I texted someone with a wet hand. So I'm sure theres water under my keypad or this little frameware device or whatever its called.(it runs your keypad...i guess) Frameware can only activate one key at a time. So I'm thinking I need a new little computer thing called frameware, or to take apart the keypad and make sure theres no water in there, even though after to days, the water should be dried up. So if it got wet, bring it to your dealer an see if they can replace the little computer deal, unless it's more than the phone itself. And if you just so happen to live in the desert and that phone had absolutely no way of getting wet, i guess them things just happen to go out for some reason. I dunno. I HATE THESE RAZRZ!!! haha. Good luck Morgan
Sep 17, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
80 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
