Question about Dynex DX-LCD37 TV
White Screen on Dynex LCD
Up until yesterday, my LCD screen was working fine. I started to notice a little flicker and then suddenly the screen turned white. It isn't completely white, I can see parts of the background, as if the coloring is off. I checked the settings and put everything into the factory defaults as well as manually tuning them to see if it makes a difference.
However, my LCD screen is fine whenever I use the input of my PS3 and Xbox360 console. The white screen only appears when I am on cable television, any assistance?
  • Anonymous Oct 25, 2008
    i have the exact same problem!
  • 38 Answers
Please stop buying these cheap things.....your out of luck. Parts are not available for these cheap chinnese sets....Thank Bill Clinton. Anyway, sound like the tuner going out. can't get a tuner...Sorry. Just try using a vcr or cable box on video input and change channels that way.
Posted on Dec 05, 2008
Dynex TV came on black and the buttons aren't working?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Dynex Televison & Video
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
Hp vs17 has white screen at boot. I have eliminated the chord from the tower and the tower works fine. I have audio, no video. Only a white blank screen. It does not blink or flicker. It just stays white....
There are three choices here...bad screen, bad connection, or bad video card, if the card is integrated onto the motherboard, then that part of the motherboard could be bad. If you have access to another monitor or a TV with a vga input, try the computer with another monitor. If you get a signal on that other monitor then you know you either had a bad connection with the other monitor or you lost the screen on the old one. Go back and reseat your video connections with the computer off. Don't ever remove or move cables to the monitor and video with the computer running...the screen can suffer permanent damage. If there is no signal on any monitor, then either you have a bad vga cord or your video graphics card had died.
Nov 11, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Sep 28, 2009 | Dynex DX-LCD32-09 LCD TV
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
I have the White Screen of Death
Try pressing the reset button underneath the antenna and if this doesn't help, then you'll need to have the LCD display replaced.
- Jim
Dec 22, 2008 | Garmin Nuvi 350 Car GPS Receiver
Dynex DX-LCD37 TV Logo
815 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
