Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Grainy picture the picture i have watching DVD's is crystal clear on my new Samsung 32" LCD HDTV, but the picture when i'm watching cable is grainy and not very clear..do i need to get a different kind of cable box since i've upgraded to an HDTV (i heard this from a friend) or is there a setting i have not set up correctly?
    Novelist:
    Champion:
  • 216 Answers
Greetings israelmaker,
In order to receive true high definition television, you will need a high definition cable box. Basic channels are going to look more grainy and not as clear overall even with an HD box, however you won't be able to view or decode the actual HD channels without a box.
In addtion, what type of cables are you using to hook up your existing box? This can have a substantial impact on the picture you see.
I hope some of this helps.
Dorothy
Go Ahead. Use Us.
Posted on Jul 28, 2008
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Panasoniv 32 inch vivera lcd tv. When I watch a movie the picture looks grainy. Kind of like the pixels are not forming to complete the picture. Am I missing a cable or some kind of compnent for...
If you're watching the movie from a DVD player, make sure all of the cables are fully plugged in and connected. If you're watching the movie from a VHS, it will probably continue to look like that.
Feb 28, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
I have a TDA-03211C 32 in. HDTV LCD TV TV/DVD Combo that will play video games and will play DVD's but will not get any channels. It looked as if the picture tube was going out when it would show Tv...
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Nov 08, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
TV channel shows up behind the picture while watching dvds!
Oct 24, 2009 | Dynex DX-L32-10A 32" LCD HDTV
Black and white grainy output to new samsung lcd
Your DVD player is using a PAL or NTSC variant which is not supported by your display. Somewhere hidden in the depths of the options in the DVD player should be an option to change the composite output type.
Jul 07, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Pixelated blacks and face shadows
take it back to where you purchased it and get it exchanged.
Jan 23, 2009 | LG 42LG50 42 in. LCD HDTV
Grainy
Unless you are watching an actual hd station this is how it is going to stay for you. Sorry your real quality comes in when you are actually being fed a true 1080 I signal not some upgraded 480.
Thanks
Josh
Jan 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
308 people viewed this question
Henry  Thomas
Henry Thomas
