Question about Nintendo Super NES Console
Snes hi. how do i connect snes to tv
It does not work with new TV's. If you have an old TV then you just plug in the "Multiout cable" into the AV inputs which are usually in the back of the TV. If you don't have the "multiout" cable then you can by it on amazon or ebay.
Posted on Aug 04, 2008
When I hook up my SNES there is no picture - what do I do?
Well onlhy use the old consoles on CRT tv styles then.
Apr 08, 2012 | Nintendo Super NES Console
My Super Nintendo is working, but won't show up on my relatively new television, can some one help me please? is there a lead or something I need to buy? thanks
Do you have your TV set to the "TV" input? There may be inputs such as "Video 1", "Video 2", "HDMI 1", "HDMI 2", "Component 1", "Component 2", etc., but the input you will want to have selected is "TV" (this is usually done by hitting a button labelled "Input" or "Video" on the TV remote). Once you are on that input, go to channel 3 (type in "03" on the remote), then turn on the SNES. It should now display.
If this doesn't work, double check the plug you have connected to on the back of the TV, it should read something like "Cable In" (not "Cable Out").
If you have checked all of that and everything is setup correctly, it is possible that you have a bad RF adapter (the grey box that connects the SNES to the TV). If this is the case you can buy one online for around $5 - $10; just google "RF adapter SNES".
Apr 08, 2011 | Nintendo Super NES Console
When i plug my snes to my tv it wont work :/ i plug the cable to tv and put the snes on chan3 then i go on channel 3 with my tv and it show me a black screen ,sometime i hear 2 sec of the game music :/
Hi pikapike,
I see you are going back to the 90's with your Super Nintendo. Firstly I do not know how you can "put the snes on chan 3". If I am correct, all super nintendo cables to the TV are RV coloured ones. therefore once it is plugged into the TV, you will ant the A/V channel? which usually has a separate button.
Secondly if what you say that you get a flash/glimpse of the game, then check the system of your TV. Is it PAL (Europe, Aus, NZ, etc) or NTSC (U.S.) Hopefully you can change the TV settings to match your game console!
Hope this helps,
kamacosmic
Feb 19, 2011 | Video Game Consoles & Games
Hi, how would i hook up my snes to direct tv box help.
I don't think you would need to hook the SNES to your cable box but only to the TV using the Red, Yellow, White cables that plug into the gaming system. If you do not have those cables you can most likely find them for cheap on www.ebay.com
Dec 17, 2010 | Nintendo Super NES Console
Super Nintendo picture flashes in & out on my flat screen
Check your cables and connection, they could be worn or cracked, try using on another tv or use a different device in the same plugins to verify if what is wrong
Dec 04, 2009 | Nintendo Super NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
SNES works but no color.
Sounds like your AV Multi-out port circuitry is shot. Yest it with an RF adapter, and if it works perfect with an RF adapter, that is the source of your troubles. I'm afraid that the cheapest solution is to buy a SNES motherboard (about $20.00), which is a lot cheaper than a repair shop soldering in new components to fix it. It's not something you can do on your own.. Google SNES Motherboards type 1 or 2
Apr 08, 2009 | Nintendo Super NES Console
Can't work SNES
Is the TV tuned to the same channel as the SNES ?
Both have to be set to channel 3 or both to channel 4.
Jan 18, 2009 | Nintendo Super NES Console
Denon 3808ci won't upconvert old video game consoles
Since the games are so old and the SNES is an ancient console most tv's are made for the newer ones/Wii, Xbox, ETc./ So The Tv May Require Certain Wires for the console to function correctly, it also may be that your wires for the SNES are corroding in side *( Copper Wires Etc. )
Dec 12, 2007 | Denon AVR 3808Ci Receiver
Super Nintendo
I'll just tell you how to set it up with an RF cable.
1: Plug the power adapter in an outlet and plug the other side in the designated spot where it fits. Simple.
2: On the back of the SNES, there should be a switch that says channel 3 or 4. Whatever one the switch is at, it will be the channel to play it at.
3: From where it says "NES CONTROL DECK" on the RF switch, plug that into the SNES.
4: From where it says "TV" on the RF switch, screw it into the supplied ports on the TV. Note that newer TV's don't have this port.
You probably don't need to bother with the antenna port.
Enjoy the SNES! :)
Nov 10, 2007 | Nintendo Super NES Console
Nintendo Super NES Console Logo
236 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
