Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
MM850 MOWER Hi, I have same problem with my MM850 B&D Mower. I wanted to replace switch with some other more simple switch (ON-OFF) but dont know where to find flick-switch that would keep RED and WHITE in connection while switch OFF and keep RED and BLACK + Black AC in ON position. I guess this my way of fixing this, but I need flick-switch to replace this stupid push switch. So my friend if you have solution for this let me know. If you need I will send my email. Thanks. Predo
  • KORGMASTER Aug 05, 2008
    Well, I think this my be possible with 3P3T mommentary ON-ON switch. (since White is brake only) So this switch in 1st ON position would pull Black and Red and connect them to Black AC feed. In 2nd ON position switch should throw Red to unused and nrutral pin where White would be connected with simple bridge wire.
    What do you think?
    Thanks
    Champion:
  • 313 Answers
Can't just replace the switch with on-off.original switch has interlocking with brake, once u pull the trigger the brake circuit will open & close when triggger is release. it is also parts of safety.must common problem is inside the switch terminal eventually the contact will burnt.
Posted on Aug 04, 2008
  • mr aicnelav Aug 06, 2008
    well how much u will spend for the switch like 3p3t on switch while the original is cost list than $15.00 & ur safe on it.
Elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Apr 23, 2010 | Black & Decker Garden
My black and Decker mm850 4.0 electric mower wont come on
should have the switch or the brush connection checked
Mar 31, 2010 | Black & Decker Garden
I JUST BOUGHT A SWITCH FROM SEARS FOR THE MM850 MOWER, BUT NO INSTRUCTIONS CAME TO SEE WHERE THE WIRES CONNECT TO. PLEASE HELP
The switch is just like any other. youll have a power and ground and maybe an accesory. put the key in the ignition switch and hook a voltmeter up to the terminals, put the meter in continuity check (the little speaker setting) when you have continuity in the meter you know thats your on setting and pins (power and ground) how many terminals do you have?
May 02, 2009 | Electrical Supplies
B&D MM850 starts then stops a few seconds later, then won't start
I was having a similar problem. I tried starting it up with the switch case open. I saw a very tiny puff of smoke come out of the switch. I replaced the switch and it was fine.
Apr 06, 2009 | Black & Decker 19" Electric Lawnhog...
Wiring problem
its unsafe to hot wire the switch. contact me at 204-783-7294 i will send you a wiring diagram ask for dennis
May 05, 2008 | Black & Decker 19" Electric Lawnhog...
Black and Decker electric mower model MM850
maybe something shorted inside mower.
you need atleast 14 gauge wire
Apr 16, 2008 | Black & Decker 19" Electric Lawnhog...
Blade lock for mm850
Use a 2x4 at least 1-3' long. Clear the grass chute so you have unobstructed passage from the back of the mower and into the blades. Wedge the 2x4 longways in through the chute and up against the blade. The other end can be **** up against something sturdy i.e. a concrete block, a wall, etc... (in my case I used my leg). Take your wrench and crank like hell.
Apr 10, 2008 | Black & Decker 19" Electric Lawnhog...
Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
478 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
