Question about Sharp AL-1217 Copier
My sharp AL-1217 greets me with a flashing "L1" error
Dear Sir,
My sharp AL-1217 greets me with a flashing "L1" error - should be scanner position error. The scanner is not locked, the unit moves from right to left when I put it manually in a different position on startup - so it seems to know that the unit is not in starting position. It runs back to the left, moves for four to five centimeters - and shows the error.
Any idea what it could be exactly?
Santanu Dasgupta
Siliguri, India
  • 30 Answers
Try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Posted on Jul 28, 2008
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
Old model AL-1217 photocopier giving error reading of L? Any thoughts, tried everything! Thanks
L1 mean scanner is not goes home position,
Solve: Clean all surface then solve your problem
Feb 06, 2010 | Sharp AL-1217 Copier
Problem with L1-00 refer to guide. Lock is unlocked, lamp carraig moves freely, drives out, then goes home. When moving slow it stops and gives the above error code
When your copier arise problem on scanner unite.
If your scanner is lock position please unlock
or clean saner all surface.
Dec 19, 2009 | Sharp AL-1655CS Laser Printer
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Aug 09, 2009 | Sharp AL 1631 Copier
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Scanner Position Error
hi i think this is carrage home position sensor problem. u check and clean the sensor and try it back. or any forign meterial blocking in carrage way.. pls check that also.. all the best..
Jun 23, 2008 | Sharp AL-1217 Copier
Scanner bar won't move
According to another source, the L1 error means "Scanner position error". Hope you find a solution, and not an expensive one.
May 16, 2006 | Sharp AL-1540CS All-In-One Laser Printer
257 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
