Question about Carrier Heating & Cooling
I have a Carrier 8000 weathermaker. Recently the blower motor began to run progressively slower and finally just bogged down. I replaced the motor, but the replacement motor has three speeds (red, blue and black wires) whereas the old motor had four (red, blue, black and yellow). Initially I hooked the new motor wires up to the circuit board the same way the old ones were, leaving an open spot where the old yellow wire was. New motor works, but at lower speeds, pushing less cool air. We live in Tucson so the unit's running all day and still has trouble maintaining temperature. I set it at 78 and the house temp will creep up to 84 by the heat of the day, and cool back down at night. This wasn't a problem before I changed out the motor. A mechanic at the store where I bought the new motor suggested I shift the wires up one spot each to get the higher blower speed the old motor had. I tried that with no change. I've changed air filters but have yet to have the freon level checked. Also, I didn't buy a new capacitor to go with the new motor as is sometimes recommended. Could that be the problem? Thanks in advance for any assistance.
Found system was slowly loosing coolant through a variety of miniscule leaks in rusting part of condenser. Apparently coolant level had dropped sufficiently in the blower repair interval to where the system no longer functioned with adequate efficiency. Bottom line - low coolant level as is the first suggestion in most related ac repair forum sites. I'm buying a Trane, this system is no longer economically feasible to maintain.
Posted on Aug 19, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
I have a Carrier Weathermaker 8000 VS furnace that intermittently has frozen up (the inducer blower stops spinning). Do I need to replace the blower or is there something else that can be done? What is the...
If you can get to the shaft of the motor, oil it using electric motor oil. If the motor spins freely, you just may need to replace the start capacitor, however if it is binding; you will need to replace the inducer as an assembly.
Jan 18, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
BLOWER NOISE
Could be a loose blower wheel. It has slipped and touching the sides of the blower housing.
Turn off the power to the nit.
Remove the 2 bolts holding the blower in place.
Make yourself a wiring schematic.
Remove the wires.
Be careful not to touch the capacitor.
Remove the blower housing.
Clean the blower blades.
Spin the wheel to see where it is hitting.
Loosen the set screw on the motor shaft and adjust your blower wheel.
Mar 10, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
How do i locate and replace the blower motor on # 58ZAV096
not sure if you have fixed the problem. There is a web site to get this motor... www.arnoldservice .com he should have the motor. I recomend a generic 3 speed mtr. you will have to cut the plug on the original as it may be a 4 speed but you only need 3 speeds. The oem motor will be more expensive then an aftermarket.
Jan 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Nov 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker SX Carrier 58SX060-cc-1
Your blower motor may have failed. Check the blower motor for the air circulation and you may find it is hot but not running. Have the motor replaced if this is the case.
Jun 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
252 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
