Question about Canon PIXMA iP3000 InkJet Photo Printer
Service error 5100
My IP 3000 can't printing rite now. the board said that it had service error 5100. i already do the instruction on it. canceled printing all document and turned the printer off. then, i try to turned on again and printed something. but, still doesn't work. can u help me please?
  • malkhzen Aug 04, 2008
    I have IP 3000 wich display that an erorr 5100 had happened . i already do the instruction on it. canceled printing all document and turned the printer off. then, i try to turned on again and printed something. but, still doesn't work. can u help me please?
  • Anonymous Aug 05, 2008
    I had installed canon pixma iP1800 inkjet photo printer. First time printing, the message Error Code 5100 appear. I've followed the instruction by switching off and on again, but it still won't work. Please help me with this since this is a newly brought printer.
    Danny05
  • 4,041 Answers
Hello it only a try but could be
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error code 5100
There is no error 5100 in the manual so look at the following:
(1) Operator call errors (by LED blinking in orange)
LED blinking in orange. Error Solution Remarks
2 times No paper. Set paper, and press the Resume/Cancel button.
3 times Paper jam. Remove the jammed paper, and pressthe Resume/Cancel button.
4 times No ink. Replace the empty ink tank(s). (Pressing the Resume/Cancel button will exit the error without ink tank replacement.)
5 times The print head is not installed properly. - Install the print head, and close the
front cover.- With the print head installed, turn theprinter off and on.
- Re-install the print head.
8 times Warning: The waste ink absorber is almost full (approx. 95% of the
maximum capacity). Pressing the Resume/Cancel buttonwill exit the error, and enable printing.
In repair servicing, replace the bottom case unit (QM2-0647), or 5-item set of
the ink absorbers
(QA4-1012/1013/1014/1015/1055).
The service call error, indicating the waste ink absorber is full, is likely to occur soon.
9 times The connected digital camera or digital video camera does not support
Camera Direct Printing.
After removing the cable between the camera and the printer, press the Resume/Cancel button, and re-connect the cable.
(2) Service call errors (by LED blinking alternately in orange and green, or lit in
orangeLED alternate blinking in orange and green
Error Solution
(Replacement of listed parts, which are likely to be faulty)
2 times Carriage error - Carriage unit (QM2-0655 / QM2-0831)
- Timing **** strip film (QA4-1053)
- Logic board ***'y (QM2-0750 / QM2-0751)
- Carriage motor (QK1-0175)
3 times Paper feed error - Timing sensor unit (QG4-0277)
- Timing **** disk film (QC1-2781)
- Feed roller ***'y (QF4-0155)
- Platen unit (QM2-0650 / QM2-0828)
- Paper feed motor (QK1-0224)
4 times Purging error - Purge unit (QM2-0825)
6 times Internal temperature error - Logic board ***'y (QM2-0750 / QM2-0751)
7 times Waste ink absorber full - Ink absorber (QA4-1012 / 1013 / 1014 / 1015 / 1055)
- Bottom case unit (QM2-0647)
8 times Print head temperature rise - Print head (QY6-0042)
9 times EEPROM error - Logic board ***'y (QM2-0750 / QM2-0751)
13 times USB Host VBUS overcurrent - Logic board ***'y (QM2-0750 / QM2-0751)
- DCD board ***'y (QM2-0825)
15 times Other hardware error - Logic board ***'y (QM2-0750 / QM2-0751)
Continuous alternate blinking
Flash ROM error - Logic board ***'y (QM2-0750 / QM2-0751)
Lights in orange
RAM error - Logic board ***'y (QM2-0750 / QM2-0751)
Hop you can understand the above as it is straight out of the service manual.
Good luck
May 24, 2011 | Canon BubbleJet i560 InkJet Printer
Ip 3000 canon showing service error 5100, tried to reset but still flashes amber. Tried nearly everything. Cartridges still full
Carriage error [5100]
Solution (Replacement of listed parts, which are likely
to be faulty):
- Carriage unit (QM2-1250)
- Timing **** strip film (QC1-4284)
- Logic board ***'y (QM2-1520)*1
- Carriage motor (QK1-0545)
Aug 04, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hi, I am trying to print a report and I get a service error 5100. I have cancelled print job and pressed ok, done this a number of times, still get the error, please help
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day. .top3Module { BACKGROUND-IMAGE: url(/images/Reviews/Top_3_BG_Asset.jpg); WIDTH: 310px; BACKGROUND-REPEAT: no-repeat; MARGIN-BOTTOM: 15px; HEIGHT: 361px } #RNR_rpt_div A { COLOR: #0033cc; FONT-SIZE: 12px !important; TEXT-DECORATION: none } #RNR_rpt_div IMG { VERTICAL-ALIGN: middle } .toptitleBest { MARGIN-TOP: 19px; FLOAT: left; COLOR: #4f81bd; MARGIN-LEFT: 19px; FONT-SIZE: 18px; FONT-WEIGHT: bold } .wrapperDiv:hover { CURSOR: hand } .wrapperDiv { FLOAT: left }
Dec 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a cannon printer mp160. I'm trying to print a document but I keep getting a service error 5100 message
Service Error 5100
Thanks.
Have a good day.
Nov 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a canon pixma ip 3000 and i need to empty inktank can u help
Ther is no ink tank it is a counter pre set by canon who decided you can only print so many pages . it is artificial number.
reset your machine by the following should help
read all first
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
to fix also :
PIXMA IP 3000 service error 5100
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down
THEN plug it in while still holding both buttons down;
Then to step 3 above.
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
Canon iP 1300
I am also with the same problem of Canon IP1300, need to know how I can solve this problem of the error 5100, as soon as I bought the product and not used yet, for this mistake, I wonder if this problem is also frequent in the canon machines? !
Jan 23, 2008 | Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
184 people viewed this question
old marine
old marine
