I need to know which fan i need for my pc
I have a older gateway computer. A 500SE I need to know which fan to get for it. Can you help me. Thanks
    President:
  • 2,351 Answers
This heatsink & fan assembly is the replacement for the Gateway 500SE & E-machine systems.
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=5564
Under the window: Search by Machine click the dropdown menue & choose as follows.
Type: Gateway Desktop Parts
Series: 500
Model: Gateway 500SE Parts
Than click submit.
Click, Cooling Fan.
More socket 478 CPU fans.
http://www.geeks.com/details.asp?invtid=CR099&cat=FAN
http://www.pacificgeek.com/product.asp?c=238&s=997&ID=39966&P=F
Most CPU fans come with the heatsink. Try not to buy a fan that comes with a grill over it. That slows the fan down & makes the fan work harder.
Mike
Posted on Aug 01, 2008
Gateway model mfatxpn1 nmz 500se - I need to remove the request for a password on booting up. I do not have any administror or guest password on my computer.
The hdd or system password can not be over ridden. Type the correct password to start boot process or fit a new hdd and install your OS then you can restore your backups.
Nov 17, 2016 | Gateway Computers & Internet
Gateway nmz500se Ethernet card does not work
did you installed the driver. go to my computer right click choose properties then go to device manager and see if ethernet it ok or it have a yellow ?.
Apr 09, 2013 | Gateway NMZ-500SE Notebook
Would like to upgrade Gateway Desk Top 500SE to a HD video
I don't think you can't do that without some major changes. The 500SE is a small format computer. The motherboard only has 2 PCI slots so you need to match that interface. NewEgg still sells the PCI video cards but I don't think they are HD
http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=48&Description=&Type=&N=2010380048+1069609642&srchInDesc=&MinPrice=&MaxPrice=&PropertyCodeValue=696%3A9642
You need a more larger power supply. The current one is a 145 watt u-ATX Form Factor; you need at least 250 watts in that form factor (size)
A better choice might be a new motherboard. Look for board with a AMD Socket 7 if you want to keep this CPU. The motherboard will need to match the size of the current one to reuse the case. It's a uATX "like" form factor (7.4" x 9.35"). Also plan on a new power supply any AGP or PCI-e video card will want more than 350 watts (for the low end cards). Getting a new computer might be worthwile.
I hope this helps.
Apr 13, 2010 | Gateway Computers & Internet
Gateway 500SE sound card driver problem
try finding the name of the sound card and then visit the realtek website to download the compatible driver k.. U can locate the name of the sound card in device manager under Unkown devices... Take care..
Sep 21, 2009 | Gateway NMZ-500SE Notebook
Black screen, no boot
Does the mobo have integrated graphics? If so, you may want to try installing a new graphics card and disabling the onboard. I had the same problem with an eMachines. When I installed the AGP card, it worked just fine.
Apr 17, 2009 | Gateway NMZ-500SE Notebook
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Check the adapter with a multi-meter to see if there is voltage at the plug that connects into the laptop. The oltage reading should be slightly higher than the voltage that is printed on the label on the adapter.
Try to borrow an adapter (same as yours) and connect it to your laptop. Also try removing the battery and power up the laptop without the battery but with the adapter connected (could be a battery problem).
Mar 29, 2009 | Gateway NMZ-500SE Notebook
Laser mouse light won't come on when is used to
If you have a USB mouse, try it on a friends PC or laptop.
if it works there then check your USB (Universal Serial Bus Controllers) in the Device Manager...
right click My Computer
select Manage
select Device Manager
from here you can check you "Mice and other pointing devices, and your USB controllers
Good Luck!
I want to expand the RAM in my Gateway 500SE computer
GATEWAY 500SE Computer Case Cover Removal before installing RAM
  1. Turn off the computer and then disconnect the power cord.
  2. On the rear of the computer, remove the three screws that secure the cover on the case.
  3. Slide the cover back about one-half inch, and then lift it from the case.
  4. Search for a small scale like card in motherboard similar to small scale as shown in figure in BANK A or BANK B.
  5. And place the another ram in free bank slot (RAM Slot).
  6. Make sure the locks are correctly locked to RAM at both sides.
  7. Close the cover
  8. Power On the System
  9. If any beep sound then switch of the system and reinsert the RAM module.
Hope this will be helpful
Thanks & Regards
Nandu
Mar 25, 2009 | Gateway 22929 Notebook
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
