Question about Nikon Coolpix 3200 Digital Camera
Battery exhausted - Nikon Coolpix 3200 Digital Camera
  • 1 more comment
  • Anonymous Nov 06, 2008
    Camera always says Battery Exhausted and turns self off
  • Anonymous Nov 30, 2008
    I have a nikon coolpix s6 we purchased a new battery and it still says battery exhausted. We purchase a second new battery and were told to immediately place the camera in the charger to charge the battery before intial use. The red indicator light is not flashing to show the camera and battery recharging. What do we do now?
  • ednaserratos Feb 01, 2009
    I have the same problem please is there any solution let me know my e mail addres is ednserratos@hotmail.com
I have a nikon 7600 when ever i turn my camera on it says battery exhausted and turns off ny its self. so i tried buying new batteries and it still did the same thing what do i do
Posted on Nov 25, 2008
Hi i am having a problem with my nikon camera.
yesterday i used it and it was alright then all of a suddeen it tell me that my battery exhausted i charge it and it still tellinfg the same thing. what can i do to slove this problem can u email me with ur advice on whatr i shiuld do.
Posted on Nov 19, 2008
Nikoncoolpix l20batteryexhausted
Posted on Jun 28, 2010
Coolpix L26 shows "Battery Exhausted" with new batteries
There is an internal battery like a watch battery. That is the one that is dead.
Jan 24, 2013 | Nikon Coolpix L26 Compact
Where are the four O2 sensors on a 2003 Montero Sport? Is $300 reasonable to replace the two upstream sensors?
According to the service literature I read, the 2003 Montero Sport with the 3.0 or 3.5 L engine does not have O2 sensors listed even in the maintenance schedule. The 2.4 L engine has it on the exhaust manifold though.
However, the following lists the par, though for before or after the catalytic converter:
http://www.partstrain.com/store/index.php?VN=4294967180+4294966587+4294964143+&Nr=AND(universal:0)&N=0&Ntt=Oxygen%20Sensor
I think that $250 to $300 is reasonable if the Oxygen sensors are stuck in there with rust and the threads are preserved by the technician. Oxygen Sensor replacement can be tricky.
Good luck on this repair.
Exhaust Manifold
REMOVAL & INSTALLATION
2.4L Engine
  1. Remove or disconnect the following:
    • Negative battery cable
    CAUTION
    Wait at least 90 seconds after the negative
    battery cable is disconnected to prevent possible deployment of the air bag.
  2. Heat cowl from the exhaust manifold
  3. Aspirator valve assembly, if equipped
  4. Oil dipstick and guide
  5. Oxygen (O2S) sensor connector and ground cable, if equipped
  6. Exhaust pipe from the manifold
  7. Exhaust manifold and gasket from the engine
    To install:
  8. Install or connect the following:
    • Exhaust manifold. Torque the M8 mounting nuts to 22 ft. lbs. (29 Nm) and the
      M10 mounting bolts 36 ft. lbs. (49 Nm). starting from the middle and working
      outward.
    • O2S sensor connector and ground cable, if equipped
    • Exhaust pipe to the manifold. Torque the nuts to 35ft. (49 Nm).
    • Aspirator valve assembly, if removed
    • Heat cowl to the exhaust manifold. Torque the bolts to 117 inch lbs. (13
      Nm).
  9. Start the engine and check for exhaust leaks.
3.0L and 3.5L Engines
    • Exhaust pipe from the exhaust manifolds
    • Oil dipstick, guide and O-ring
    • Heat shields
    • Exhaust manifolds
  2. Clean the gasket mounting surfaces. Inspect the manifolds for cracks,
    flatness and/or damage.
    To install:
  3. Install or connect the following:
    • New gasket and exhaust manifold. Torque the nuts to 33 ft. lbs. (44 Nm) on
      3.0L engines and 22 ft. lbs. (29 Nm) on 3.5L engines.
    • Heat shield, Torque the bolts to 10 ft. lbs. (14 Nm).
    • Exhaust pipe to the exhaust manifolds. Torque the nuts to 35ft. (49 Nm).
    • Oil dipstick, guide and new O-ring
  4. Start the engine and check for exhaust leaks.
Oct 07, 2010 | 2003 Mitsubishi Montero Sport
Where are the exhaust system bolts located?
Removal & Installation 2.2L Engine To Remove:
    • Negative battery cable.
    • Heat shield.
    • Oxygen sensor.
  2. Raise and safely support the vehicle.
  3. Remove exhaust pipe from the exhaust manifold.
  4. Lower the vehicle.
  5. Remove the exhaust manifold mounting nuts from the cylinder head. chevy_cav_02-04_exmanifold.gif
  6. Remove the exhaust manifold.
  7. Clean the mating surfaces.
  8. Check for cracks, broken flanges and gasket surface damage.
  9. Use a straight edge and a feeler gauge. If the flanges or the mating surfaces do not align, the manifold is warped and should be replaced.
To Install:
NOTE: The manufacturer recommends using new exhaust system nuts.
  1. Install the manifold gasket.
  2. Position the exhaust manifold to the cylinder head. Exhaust manifold 2.2L 87953055.gif
  3. Install the new exhaust manifold nuts. Tighten the nuts starting from the center and working toward the ends to 110 in lbs (12.5 Nm).
  4. Raise and safely support the vehicle.
  5. Install the exhaust pipe to the manifold using a new flex coupler gasket.
  6. Install new exhaust flange mounting nuts.
    • Tighten to 33 ft lbs (45 Nm).
  7. Lower the vehicle.
  8. Install the oxygen sensor.
  9. Install the heat shield.
  10. Connect the negative battery cable.
2.4L Engine To Remove:
  1. Disconnect the negative battery cable
  2. Disconnect the Oxygen (O2) sensor electrical connector.
  3. Remove the (O2) sensor.
  5. Remove the exhaust manifold brace-to-manifold bolt and the oil pan nuts, if necessary. Exhaust heat shield 2.4L 87953051.gif
  6. Remove the upper heat shield. NOTE: Do NOT bend the exhaust flex decoupler more than necessary to remove it. Excessive movement will damage the flex decoupler
  7. Remove the manifold-to-exhaust flex decoupler fasteners.
  8. Remove the exhaust pipe.
  9. Carefully lower the vehicle.
  10. Remove the exhaust manifold-to-cylinder head mounting nuts/bolts. Remove the exhaust manifold.
  11. Discard the gaskets and/or seals. Clean the mating surfaces.
To Install:
  1. Install new exhaust manifold gaskets. Position the exhaust manifold on the cylinder head. Tighten the mounting bolts in sequence to 110 in lbs (12.5 Nm).
  3. Install the exhaust manifold heat shield. Tighten the mounting bolts to 10 ft. lbs (14 Nm).
  4. Install the exhaust manifold brace-to-manifold bolt and the oil pan nuts. Tighten the mounting bolts to 41 ft lbs (56 Nm) and the nuts to 18 ft lbs (24 Nm).
  5. Position the exhaust pipe to the manifold. Install the manifold-to-flex decoupler mounting bolts. Tighten to 26 ft lbs (35 Nm).
  6. Lower the vehicle.
  7. Coat the threads with a suitable anti-seize compound and install the O2 sensor.
  8. Connect the O2 sensor electrical connector.
  9. Connect the battery ground cable and check for leaks.
Sep 02, 2010 | 2000 Oldsmobile Alero
How is the manifold removed on 2005 lincoln ls? Where is the bolt that holding it down?
Exhaust Manifold - Removal & Installation3.0L Engine
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Remove or disconnect the following:
    Negative battery cable Heat shields Lower splash shields Exhaust front pipes Secondary air tubes Exhaust Gas Recirculation (EGR) tube Exhaust manifold
To install:
Fig. Right exhaust manifold torque sequence-3.0L engine
Fig. Left exhaust manifold torque sequence-3.0L engine
  1. Install the exhaust manifolds. Tighten the fasteners in sequence as follows:
    1. Step 1: 15 ft. lbs. (20 Nm)
    2. Step 2: 15 ft. lbs. (20 Nm)
  2. Install or connect the following:
    Exhaust Gas Recirculation (EGR) tube Secondary air tubes Exhaust front pipes Lower splash shields Heat shields Negative battery cable
  3. Start the engine and check for leaks.
continue...
Jun 21, 2010 | 2002 Lincoln LS
Nikon L100 shows battery exhausted error message after installing new batteries. Unable to perform any operations on camera
That's the bug in Nokin L100, update the firmware version from 1.0 to 1.1, this will solve the battery exhaust problem. Firmware version 1.0 has only 2 battery (Alkaline and Lethium) option where as Firmware version 1.1 has Nickle battery also. But, to update the firmware you need to have EH-67 AC Adapter to give power to the camera.
Jan 24, 2010 | Nikon COOLPIX L100 Digital Camera
Batteries Exhausted Message on Nikon Coolpix L18
How could I resist assisting someone with the handle 'Charm City'? What I would advise is getting some good quality 2300 mAH or 2500 mAh re-chargeable batteries - although all batteries have a nominal 1.5v output, not all can provide the sustained power necessary for the camera.
Aug 19, 2017 | Nikon COOLPIX L3 Digital Camera
Camera showing battery exhausted with new batteries
There are three battery type settings in the set up menu: Alkaline, COOLPiX(NiMH) and Lithium. Might be worth looking at. To be continued.
Jan 29, 2008 | Nikon Coolpix 5600 Digital Camera
Battery EXTREMELY Exhausted
You MUST use rechargeable batteries , like NiMh , with charger for that kind of battery , and your problem will go ...
May 25, 2007 | Nikon COOLPIX L3 Digital Camera
Exhaust my main battery
It is estimated that you will have a few days to recharge your battery if the battery is exhausted.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Nikon Coolpix 3200 Digital Camera Logo
3,412 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
