Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag Neptune TL FAV6800A/9800A
Do you still have the manual for this unit? If so could you please let me know. I can provide an upload site to up it to. Thank you.
Smitty
leonnwilma(ampersand)hot(what the postman delivers)dot(short for commercial)
Not looking for a sales pitch. If I wanted to buy a new unit I wouldnt be here looking for a manual to fix my present unit with now would I.
Posted on Aug 21, 2008
Neptune TL Washer FAV6800AWW need owners manual
Google This ""Neptune TL Washer FAV6800AWW""
5th post down is a link for the FAV6800A/FAV9800A SM.
Aug 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I've got a crack in the inside tub. The fiberglass part. How do I remove the one side to repair this. And I take it 'J B' Weld will do the trick? LOL Thank you, Mary
Mary,
Google this ""16022808.pdf""
That will you take you to the FAV6800A/FAV9800A Service Manual. The SM will take you thru front panel removal. the front panel and the washer top raised are the only access points for the FAV6800A and FAV9800A Maytag Neptune TL's.
JB weld should do it. I would rough up the crack area and place pice of fiber glass mat and resin.
Mary,
That will you take you to the FAV6800A/FAV9800A Service Manual. The SM will take you thru front panel removal. The front panel and the washer top raised are the only access points for the FAV6800A and FAV9800A Maytag Neptune TL's.
JB weld should do it. I would rough up the crack area 60 grit light sanding and place piece of fiber glass matt and resin.
How did this happen? Any sever wash tub swings in Spin Cycle?
I don't use this forum for deeper DIY support it's too difficult to find my older post for reference and no editing features.
Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" I support a lot of owners like you and myself at that site. Fixya is OK if you can get help for this TL.
Good Luck dh1200s
If your machine is a FAV6800A or FAV9800A here is a pic with the front panel removed. I'm working on preventive maintenance for DC/UC unbalance errors associated with the Clutch Pulley a common failure with this TL..........Good Luck dh1200s
Pic with the outer tub removed for Outer Tub bearing rebuild work.
Aug 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
How do you remove the fabric softener insert?
See page 33 and 34 of the FAV6800A/FAV9800A Service Manual for Bleach/Softener Dispenser Removal.
The only place I know of to get the Service Manual is at a DIY appliance repair forum like this forum with the Sticky Neptune TL Washer FAV6800AWW
5th post down has a link to the FAV6800A/FAV9800A SM. Post in that forum if you need additional help and good luck.........D*ick
Feb 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl what is code Lr
LR is the error code for Locked Rotor.
This could be an issue with the Motor Controller or Control Board.
I have not seen Drive Motor cause this issue to date.
If you want to investigate further I would suggest getting the FAV6800A/FAV9800A Service Manual.
Google this ""Neptune TL Washer FAV6800AWW""
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
WHERE CAN I GET THE SERVCICE MANUAL FOR FAV6800AWW IT HAS BEEN DISCONTINUED/IS THERE A PDF SITE
Yep
Google "Sticky: Neptune TL Washer FAV6800AWW"
5th post down I start with Sticky DIY info this site has the 16022808 Revision 0 December 2003
My site of choice for helping owners with FAV6800A/FAV9800A issues.
Feb 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Why is my Maytag Neptune top loader continually reading "dc" and is not completing wash cycle?
You can't get the FAV6800A/FAV9800A Service Manual from this site.
Google this ""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
Jan 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
We have a maytag neptune TL. Usually when you hit start to run a load a little water comes out of the discharge hose. It is not doing that. It runs in the wash cycle for about 8 minutes the it pauses...
If the machine is a FAV6800A or FAV9800A google ""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
If the machine is a FAV6800A or FAV9800A you can go into Service Mode and tes the Drain Pump. Then we can start to troubleshoot the issue if the above model is your machine type.
This site is not really geared up for DIY folks.
Jan 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
How to repair water over load on a maytag neptun fav6800w
I don't like using this forum but I will get you started.
Google this without the quotes""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
Will the water turn off if you hit the OFF buton on the console or pull the 120VAC power cord to the washer?
Issue could be a Stuck open Water Inlet Valve or improper signaling from the Pressure Switch for water fill in the wash tub.........**** dh1200s
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Caught string
OK you can remove thr tumbler with a Number 20 Torx driver. The FAV6800A/9800A Service Manual does not call out the torx driver size. Page 37 of the SM will take you thru the process. Let us know if you have any questions. Rich
Apr 09, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
