Question about Whirlpool Duet GHW9150P Front Load Washer
F 21 where is the pump located? I don't want to tear apart more than necessary
  • darcyd Jul 30, 2008
    washing machine not spinning comes up fault clean pump where is the pump
  • 770 Answers
Remove the bottom panel 3 scres and you will see it check the filter there for a blockage
Posted on Jul 30, 2008
Getting to timing chain without tearing down engine 2000 dodge intrepid
I assume you're talking about the 2.7L V6. As you're probably aware (having had it apart before), the timing is properly set by aligning the colored links on the primary timing chain with the marks on the crank sprocket and cam sprockets. The only way I know of to see all these at the same time is to remove the timing cover, and you have to tear the engine apart to remove the timing cover.
Oct 29, 2016 | Dodge Cars & Trucks
2004. What is the book time/all data to do the timing belt & tensioner on my car?
if this is a 4 cylinder then it will be about 3 hours. you should replace the belt tensioner while in there and the water pump so you don`t have to pull it apart again. you can buy timing belt kits that come with the necessary belt, tensioners, but not water pump.
Aug 21, 2015 | Hyundai Accent Cars & Trucks
21 hp rider smokes it is not pumping oil in the carb.blowing some oil aroung the dip stick cylinder and piston look fine. valve are carbon up from burning oil what u think.
Unless you got some bad gas it sounds like you need a tear down and rebuild. As your rings may look ok there is a tight tolerance for rings and valves for that matter. If problem persists I would take to a trusted local shop for a rebuild.
Aug 10, 2013 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Locating my EGR solenoid on my 95 S10 4cyl
It is located between the EGR valve and the intake vacuum source, one line gores to a vacuum port on the intake and the other to the EGR valve, just follow the lines.
May 24, 2017 | Cars & Trucks
Where is the location of drain pump
With alot of front loaders, you have to nearly tear apart the entire machine to get to the pump! You're better off having a repairman do the work for you.
Apr 30, 2012 | Kenmore HE2 Plus Front Load Washer
Where can I find the starter on my 02 honda shadow? Don't wanna tear apart the whole engine if I don't have too lol
just follow the hot side battery cable and it should lead you to the starter. hope that helps you.
Sep 02, 2011 | 2005 Honda Shadow Spirit 750
How do i change the oil pump in a 2000 dodge intrepid
I'm assuming that you are talking about 2.7L, the check this procedure...
Removal & Installation - 2.7L Engines
  1. Drain the engine oil.
  2. Remove or disconnect the following:
    Crankshaft damper Timing chain cover Timing chain Crankshaft sprocket Oil pan Oil pickup tube and O-RING Oil pump
To install:
Fig. Oil pump mounting bolt locations-2.7L engine
  1. Fill the oil pump rotor cavity with clean engine oil.
  2. Carefully, install the oil pump over the crankshaft and into position.
  3. Install the oil pump mounting bolts and torque to 21 ft. lbs. (28 Nm).
  4. Lubricate the new pickup tube O-ring with clean engine oil and torque the pickup tube mounting bolts to 21 ft. lbs. (28 Nm).
  5. Install or connect the following:
    Oil pan Crankshaft sprocket Timing chain Timing chain cover Crankshaft damper
  6. Fill the engine with clean engine oil.
  7. Start the vehicle, check for leaks and repair if necessary.
Hope helps (remember to rate this).
Oct 02, 2010 | 1999 Dodge Intrepid
Why is my harward pro grid de filter shooting out all the debris it collects? It will collect and hold it all day until it restarts the following morning and then it will shoot the de and all other debris...
Chances are you have a torn grid inside, sometimes debris will cover the tear while it's running, then when the pump shuts off the debris settles to the bottom of the tank. Then when the pump turns back on, it shoots DE and debris through the tear until something else plugs it. Tear the filter down and inspect the grids, replace as necessary.
Nov 16, 2009 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
Hi, bottom of pool is clean that morning, I run the pump and at the end of the day there will be quite a bit of dirt and what looks like tiny bugs on the bottom. It's like the pump is passing stuff right...
It may be the filter unit. If it's a DE filter, it's possible that one of the cartridges inside has a hole, rip, tear and the debris is getting back in... is it cloudy at all? Make sure that the diverter top is put back on in the exact same location as you had it before...
Aug 02, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Whirlpool Duet GHW9150P Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal De
