Question about Viking Kitchen Ranges
Spark ignition continues to spark viking rangetop
    Novelist:
  • 116 Answers
The ignition module has a feature where if there is no flame it will continue try it re-ignite by sparking. If there is flame then it will shut off. Try using a mild abrasive cloth or sand paper to gently clean the contact points between the igniters and burners, A green scratch pad (scotch-brite)works great for this.
If the metal is clean and the problem still persists please have a tech verify the problem as you may need a new ignition module.
Posted on Jul 28, 2008
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
Igniter keeps clicking, intermittent
There should be a little switch that slips over the stem of each burner control. Very common.
Jun 02, 2009 | Viking VDSC307-4B Dual Fuel (Electric and...
Wolf Sealed Rangetop Stopped Igniting
Do any of the burners click? If not, you may need a new spark module. If only one isn't clicking you may need a new ignition switch that is just behind the knob. I have also seen wires get pinched,stopping the flow of electricity. It may also be a computer board issue which is rare. Sooo you really need to call for service.
May 28, 2009 | Wolf Manufacturing Gas Kitchen Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
I have a viking rangetop and the griddle's gas is not turning on the glow plug works fine but no gas seems to be coming out.
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
Sep 06, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
Nov 21, 2007 | Viking VGSC366-6B Gas Kitchen Range
Kitchen Ranges Logo
1,028 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
