I plugged in my new verbatim Portable hard drive 160G. USB 2.0 but my computer isn't registering it. I have a pc windows 2000. The blue light is flashing however
    Genius:
  • 2,785 Answers
Have you formatted the drive
Posted on Jul 28, 2008
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
I have a verbatim 320GB externam hard drive the model is CLON320GB. One day it just stopped registering on the computer. At first it woulod make a constant beeping noise when I plugged it in but would not...
From the information provided, it appears to be a direct hardware failure. Verbatim appears to not offer much on providing information on such issues, so it would be safe to say is have it replaced.. I am not 100% sure but some external drives come with a 7 year warranty, you could also try to have your data recovered from a local computer service in your area so you do not lose the data. But, in all it would be advised to replace it.
Jul 13, 2011 | Verbatim 96823 320 GB USB Portable (Blue)...
How do I use your Verbatim? Please give me instructions
From Verbatim "Installing your portable hard drive is extremely simple - just use the included mini-USB cable to connect your hard drive to any free USB port on your computer. On Windows computers, a new icon will appear in My Computer representing your hard drive. On Mac OS systems, your hard drive will appear on the desktop as a new disk."
Jun 11, 2011 | Verbatim 320GB USB Portable Hard Drive
My portable hard drive wont connect to my computer. When I plug it in a blue light on the device light up, and it makes a constant beeping sound, but my computer does not register the device. It works on...
hi there,
While the Hard drive is connected to one of the USB ports on your computer.
On your keyboard press and hold the power button and press the letter R.
When the Run box comes up type in devmgmt.msc
Expand the Universal Serial Bus cotnrollers
right click on every root hub and choose uninstall
after that restart the computer
Hope this helps!
May 05, 2011 | Verbatim 96823 320 GB USB Portable (Blue)...
I've plugged a portable harddrive in and it's not being recognized. It's a Verbatim USB 320. I am on a Toshiba with Windows 7
The USB memory key want to use a drive letter already in use. To fix it ,click on start,right click on My Computer then click on Manage. You may need to enter your password or click on Continue in the User Account window. Click on Disk Management and look for an entry that does not have a drive letter. Right click on the drive and then click on Change Drive Letter and Paths. Click on the Change button and select a new drive letter from the dropdown menu.Click OK in both windows to save.
Regards Bill
Apr 15, 2010 | Verbatim 96823 320 GB USB Portable (Blue)...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
Portable hard drive won't show on desktop
it could be defective cause you might have taken the stick off while it was loading or if not you can plug it again and try opening it through My computer/ Removable disk:
Jun 19, 2008 | Verbatim VER95327 USB Hard Drive
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Computers & Internet Logo
David Payne
David Payne
